Linux Fu: Speak Up!
Apparently, people hate typing. As every movie and TV show suggests, the future is talking to computers. There was a time when speech recognition was complex and not very good. But these days, even our lowly phones can do a pretty good job of speech recognition. Of course, one problem is that your phone probably isn’t actually doing the speech recognition. It sends it to the big business of your choice to interpret. I’ve been using Handy, a speech recognition system that works well for me. I’ve also looked at some that didn’t.
After all, it is sometimes nice to dictate to your computer, and it would be even nicer if you could keep your data local. On Windows, oddly enough, there is a well-developed speech feature that, as far as I can tell, almost no one talks about or uses. One video estimates that 99% of users don’t use it. Linux, of course, has many options, but historically, these have been difficult to set up or finicky.
Of course, the good news is that many of the Linux tools are open source and the models are quite good. That means other people have had the freedom to fork the tools and make them easier to use, at least in theory. The licensing of the models themselves may be different, but those will be hard to modify, anyway and they generally work well. The biggest problems on Linux isn’t the technology itself, but the tremendous variety of systems and setups.
Suppose you want to write a speech-to-text program. Will it work on ARM? What desktops will it integrate with? Can it use a GPU? What kind? What about specialized instructions in some CPUs? Then there’s the forced input situation; typing into arbitrary programs once you know what the user said. On X11, it is easy, but Wayland needs different handling.
A Shortcut
I’ve thought about using my phone with KDE Connect, which is an excellent program. It can let you use your phone as a keyboard and mouse for your Linux computer. Unfortunately, it is aimed at character-at-a-time input, and I’ve never found a way to make it work with voice.
Besides, the phone is beaming all the data to “the cloud.” You probably type things you’d rather not broadcast to the ether.
I had looked at Speech Note before, but it is sort of a speech recognition notepad. I didn’t find it seamless, and it didn’t work well on my system anyway. Vocalinux looks nice, but a quick test kept complaining that my Intel extensions were not available. Makes sense, since I have an AMD CPU. Even though the documentation said it should work, I was never able to get it to work.
The Easy Way
Turns out the application that worked readily on my machine was Handy. Keep in mind, Handy is just another tool that uses one of several models out there, along with other open-source tools. You might need to install some tools to deal with your system like xdotool or dotool, but they are probably already installed anyway. That isn’t to minimize the value of Handy. It is — well — Handy. You don’t have to load and configure models, set up a bunch of system-level hooks, or install a bunch of libraries. You install it, and it works.
You can configure it. The best model for you, for example, may depend on your machine and the languages you speak. You can configure the hotkeys and how the app types into your computer. But it does all the work of downloading and configuration. Continue reading “Linux Fu: Speak Up!” →
Every ZX81 Expansion Card You Ever Wanted, All At Once
The Sinclair ZX81 was a masterpiece of Sir Clive’s desire to get the most out of the least hardware, being about as minimalist as it was possible to get and still be a home computer in 1981. As such it has a keyboard, a Z80, TC and cassette interfaces, 1K of memory, and that was it. There were any number of add-ons for it, but if you were a 1980s kid the chances are you couldn’t afford them. So 45 years later here’s [adam.klotblixt] with OpenSpand — every ZX81 expansion you could think of, all in one!
For a start there’s a RAM expansion. Not the paltry 16K of old, this is user-configurable and has the whole 64K address space minus the ROM to play with. Then there’s SD card storage, hijacking Sinclair BASIC’s LOAD and SAVE commands. It’s got high-res graphics, emulated sound chips, a joystick port, serial ports, a choice of ROMs, and a composite video output. Perhaps the only thing it doesn’t have from back in the day is a printer interface, but we’re sure the serial port could be pressed into service somehow.
It does this all as you might expect these days, with an RP2350 emulating the real parts. The microcontroller disables the onboard RAM and ROM and emulates those too, such is the disparity in power between it and a Z80. We would have done anything for this expansion, back in the day.
The ’81 features here quite often, most recently in a look at Sinclair’s own RAM expansion.
Fixing A Ubiquiti 16-Port PoE Switch With An Extra Hole
After saving a £300, 16-port Ubiquiti network switch from getting tossed into the trash, [Buy It Fix It] got the honor of trying to repair it. With four ports and their associated PoE function having some major issues it looked like it might take some debugging, but after taking the lid off, the cause seemed rather obvious.
One of the Broadcom BCM5911 controller chips had a rather suspicious chip of the plastic packaging missing, with additional probing of connected components showing that numerous MOSFETs and a diode having had their proverbial guts blown out and were shorted as well. Whatever happened to some connected Ethernet device would appear to have left a serious trail of damage that nearly wrecked the entire switch.
The biggest challenge here was probably to find a replacement for the Broadcom IC, as this isn’t an IC that stores like Digikey or Mouser stock any more. Fortunately it was still available for sale over at AliExpress for £1.84, with the usual caveat that it could be salvage, fake, a factory reject, etc. In this case it appears that it was a legit Broadcom IC, with the four affected ports springing back to life including powering a PoE camera.
With a total cost of about £5 plus the time invested it wasn’t a bad deal to save a pretty nice PoE switch with 16 Ethernet and 2 SFP ports.
Continue reading “Fixing A Ubiquiti 16-Port PoE Switch With An Extra Hole” →
