After saving a £300, 16-port Ubiquiti network switch from getting tossed into the trash, [Buy It Fix It] got the honor of trying to repair it. With four ports and their associated PoE function having some major issues it looked like it might take some debugging, but after taking the lid off, the cause seemed rather obvious.
One of the Broadcom BCM5911 controller chips had a rather suspicious chip of the plastic packaging missing, with additional probing of connected components showing that numerous MOSFETs and a diode having had their proverbial guts blown out and were shorted as well. Whatever happened to some connected Ethernet device would appear to have left a serious trail of damage that nearly wrecked the entire switch.
The biggest challenge here was probably to find a replacement for the Broadcom IC, as this isn’t an IC that stores like Digikey or Mouser stock any more. Fortunately it was still available for sale over at AliExpress for £1.84, with the usual caveat that it could be salvage, fake, a factory reject, etc. In this case it appears that it was a legit Broadcom IC, with the four affected ports springing back to life including powering a PoE camera.
With a total cost of about £5 plus the time invested it wasn’t a bad deal to save a pretty nice PoE switch with 16 Ethernet and 2 SFP ports.
Continue reading “Fixing A Ubiquiti 16-Port PoE Switch With An Extra Hole”
