Palm OS, an operating system for a range mobile devices that predated mobile phones, is largely forgotten today. Or at least, that’s what [Aaron Ardiri] thought.
That all changed when he was contacted by a developer about some Palm OS software he had written decades ago. He soon realized there was a whole community of enthusiasts enthusiastically exploring a platform he had assumed was a forgotten layer in the strata of early mobile computing history.
This led [Aaron] to dust off and publish his substantial personal archive of development tools, source code, documentation, and more all related to his years of working with Palm OS in the early days of mobile computing.
When it comes to the importance of preserving computing history, we can’t put it better than [Aaron] himself so we’ll just quote him here:
Preservation is not simply about keeping old files. Source code, tools and documentation provide a record of how engineers solved problems under the constraints of their time. They also preserve knowledge that is easily lost when companies disappear and platforms are discontinued.
In many ways, Palm OS devices like the PalmPilot have very little in common with modern mobile computing platforms. They had to do more with less, and development reflected that. If you’re curious what these devices were like, here’s a great tour that includes a browser-based emulator.
When an 68k with just two megabytes did what now needs eight multi-gigahertz ARM64 cores with eight gigabytes and up.
just imagine what us old developers can do on these new machines … I go barebones as much as possible and avoid frameworks like a plague haha
The old developers at my work talks like this too, but it turns out that to take advantage of the hardware like they are suggesting takes ages. It’s almost like the most expensive resource is developer time.
With the advent of AI coding, that may not be such an issue any more.
I believe you’re half right. Law of diminishing returns. Up till now developer time was certainly the limiting factor, but with AI doing the heavy lifting so often now, I think we’re going to see a whole new perspective revealed. Human creativity and problem solving generally come to the fore. Either that or as some predict, the human touch will prove useless and everything will be made by machines. I very much doubt the machines are taking over on that level, but where we are is undeniable. Time will tell. Oh and to be clear, old fart (hobbiest) developer here…bear metal all the way!
I think it was a different mindset back then – I remember a lot of weekends when I would get on the “creative juice”.. doing what we were doing was not only cutting edge, but it was also very stressful – especially when we started securing some serious projects where things did look totally impossible.. but, after a night out – and a hangover.. we always pulled it off.
Just imagine if we had the tools that are available today.. in a way, I am still doing the same – but at a pace that is incredible now that we have AI – if you know how to use the tools, you can accomplish anything
A master lead swinger like the plague ha ha.
It depends on the task, the framework and just how low level you are talking about going.
I work in a Mickeysoft shop and frequently have to consume 3rd party APIs with Mickeysoft’s WCF. I could easily do what takes me a month of office hours fighting with WCF in a few days using a platform where I can just read/write raw payloads and nothing more than the typical string functions that almost every language inherited from C.
Writing everything in machine code from scratch would be ridiculous but not every layer of abstraction saves developer time or makes anything better.
the problem is the browser…if you didn’t want the browser in your pocket, there would be a reason to strive for this efficiency. but as long as you’re gonna run a browser on everything, there’s no incentive to chase the little stuff.
There were a lot of real limitations too though. Take for example the lack of wifi support on the 68k devices (without an expensive external add-on to do the heavy lifting) as they lacked the grunt to handle even the simpler encryption required for wifi a/b standards along with a full software TCP/IP stack. We had to wait for the move to PalmOS 5 on ARM devices before fully integrated wifi support was practical. A similar story played out with mp3 playback capability as well with only the fastest end of the line 66Mhz 68k Dragonball CPU being able to handle it natively, but the shift to ARM CPUs made mp3 (and even SD video) playback support pretty much ubiquitous overnight.
should check out some of the source code to some of our games (on GitHub too).. we found a few nice tricks to end up with read only memory for bitmaps.. you could do a lot with a well designed memory pagination system.. HTTPS wasn’t really a thing back then – but HTTP was possible.. with your own encryption.. I had full OTA support for data in some of my commercial apps and it was encrypted communication and had full DRM capabilities for licensing.. nothing is impossible ;)
Love this!
Even the PALM FOLEO SDK is in there! For anyone who doesn’t remember it was a tiny Linux laptop meant as a companion for your TREO smartphone, dependent on it for data connectivity. I’ve never seen one for sale, they may have never gotten past prototype stage. The specs for them were underwhelming for the time.
Also as a weirdo who often uses Palm OS apps in an emulator on an iPhone (their PIM apps really are the best still), this is one of the most exciting hackaday posts I’ve seen in weeks :)
I gave mine (pre-release) to Dmitry – who has been able to recover it and find some cool stuff on it.. the dev kit in the repo was on the CD ROM included. ;)
Dmitry also got a lot of other prototype and pre release hardware – it has been sitting in boxes for almost 20 years and there is an excellent community out there that can hopefully take all this info and do something cool with it
did you not see the Access Linux Platform SDK as well? :) the Foleo also used Linux .. so there was some synergies there.. i am open to adding more stuff – Brian Hall from mark/space sent me a few cool tidbits I committed today
Any worries about the current copyright owners? I remember the SDK having a pretty restrictive EULA.
it’s been 25+ years..
if there is any company still out there that has issues – they can make contact and we can sort it out.. I have a lot of stuff I never published (roms, simulators) – but a lot of it is available via third parties..
this is all about preservation of a platform that was awesome.
PalmOS got sold off and still exists, called GarnetOS nowadays. They might care even if the rest of us don’t and have never heard of them.
I’ve heard of them but I’ve no idea what they do. Don’t really care either.
Reading this post I had to look in my stash… I still have a Palm V and two Palm VII’s (one with a crack in the screen). Grabbed a couple of AAA’s and the (undamaged) Palm VII powers up and goes through it’s set up routine. Even accepted 2026 as the current year.
To Quote Will E. Coyote; Now that I’ve got you, what do I do with you?
Now if only someone could remind me what game I used to play on my mother’s Palm back in the day.
It was some sort of space game and I think I was flying around trading between star systems. I think there was combat too.
We only had the demo of it, might’ve come on a demo multipack.
X3 which was developed by Ivo Jager?
I remember he was working on a game like that – it would be almost impossible to find with a name like that these days ;)
Hi, maybe it was Space Trader?
https://en.wikipedia.org/wiki/Space_Trader_(Palm_OS)
https://www.mobygames.com/game/39999/space-trader/screenshots/
Pretty darn certain it was this after checking it out. The name should’ve been a bit of a giveaway.
Though it is weird that I could swear I had a point where I reached the end of a demo with it and it wanted us to buy the full version. Since it’s apparently GPL it’s completely free
If the replies below don’t mention the game you’re looking for, communities like /r/tipofmysjoystick on Reddit are really efficient for finding games from old memories, you should do a post there.
I really loved the keyboard on the Handspring Treos. And am really annoyed that people think that the first touchscreen phones were iphones!
Very timely article :) I just dusted off an old Treo last weekend. Glad there is such a lively community still chomping away :)
I used my Palm as a pocket RS232 terminal for the automation equipment I worked on in the past. Instead of booting up my computer and waiting to load ProCom Plus, I could just plug my Palm in and instantly be talking to my equipment.
