Flying An RC Airplane With Twin Airblower EDFs
Shortly after [RCMakerLab] posted his question on potentially equipping an RC airplane with the electronic ducted fans (EDFs) from those airblower devices – are sold mostly as a replacement for canned air – the comment sections pretty much exploded with comments that he should just have strapped them onto an RC airplane and see for himself. In a new video this is exactly what is done, creating a somewhat A-10 Warthog-esque RC plane with its twin EDF turbines.
After we first covered this journey, the next question that got answered in the subsequent video was whether replacing the default electronic speed control (ESC) would make sense, mostly to lighten the load and optimize it for use with a typical RC avionics controller.  This turned out to be the case, and thus it’s time for a test flight.
The aircraft created from largely styrofoam board seems to be largely designed for stability, with its large wings and the very A-10-like placement of the turbines right above the tail with its twin vertical stabilizers. It wasn’t really a shocker to see that the resulting 368 gram light airplane actually flies pretty well, with it taking off almost immediately.
With the used 2S1P, 1300 mAh Li-Po battery total flight time is about 3-4 minutes, which seems about on par with typical numbers. With a larger airplane and battery these two EDFs probably could be pushed even further, which we fully expect to see in a future video.
14 thoughts on “Flying An RC Airplane With Twin Airblower EDFs”
  1. You could probably do a “blown wing” fairly easily with these fans and get an improvement in STOL performance for free. A bit like the AN-72 but without the hassle of hot jet exhaust.
    1. I don’t mind that–instead the past, articles often had one generic stock photo serve multiple purposes. That got as old as seeing that one Cylon ship veer to one side to get blasted+-or V-2 footage no matter how the model was shaped.
      Now for the article at hand….I see a quieter option:
      https://m.youtube.com/watch?v=RlgKgpLNVc8&t=32s&pp=ygUYQHBsYXNtYWNoYW5uZWwgYmxhZGVsZXNz
      I’d like to see not only ion thrusters, but an entire ion wind airship with flex-solar envelopes powering annular rings around a dirigible such that the whole thing becomes an air warp nacelle.
      The gondola would be attached to a wide, loosely folded parachute underneath the envelope.
      But I want to go even further.
      Can you combine different propulsion types?
      Take the ion wind thruster above, and combine it with this:
      https://thedebrief.org/this-is-the-closest-thing-to-magic-massless-ultrasound-tube-moves-matter-through-the-air/
      Perhaps for combustion of chemicals that would foul tubes… dicyanoacetylene and FOOF…hydrogen plasma and fluorine plasma for about a thousand seconds of specific impulse.
      Might concentric aerospikes/RENE rocket rings be similar?
      The idea is to find ways to not even need blades or propellants to physically contact ANYTHING….sonics and electronics working together with a plasma window to keep things working in a vacuum….a way to have V-1 pulse jets even work in space…
      1. Sorry to say this, but we were there in the last century. The problem with ionic propulsion of air is, that it’s weak and inefficient. Unless you put it in a vacuum to accelerate electrons (ion thruster) or use it to propel plasma (RAMjets). But there the problem is the heat melting stuff, so there’s that.
        1. That’s why the concept of jacketed thrust needs to be looked at.
          The linear aerospike uses the atmosphere as part of the nozzle, correct?
          If you have concentric, nested aerospikes, perhaps you could use cooler exhaust products to act as a nozzle for more fiercely burning reactions.
          Outermost ring hydrolox surrounding methalox surrounding FOOF/dicyanoacetylene.
          The Nuclear Salt Water Rocket would give constant thrust unlike pulse-Orions, but also suffer from heat.
          The work around I mention above might help with that.
          Perhaps a 3D printed solid rocket or ablative grain would allow autophage (self-eating) rockets that burn like cigarettes to ablate and take the heat with it.
          The TED talk about Unilever nozzles could perhaps be used to design Tesla tubes that feed liquid out the bottom as part of the 3D print.
          All that burns away but you have liquid channels the whole length of the rocket freshly exposed.
  2. I hate that all thumbnails are now AI gen.
    I don’t get it. Surely it’s less effort to just pull a still from the video that you have already made. Or just take a photo of the thing and use that as the thumbnail.
    1. Youtube thumbnails are an arms race with the algorithm and the lowest common denominator viewer. There is a reason why they are so often ridiculous and have silly trends, like having “ILLEGAL” in giant bold block letters for no apparent reason, and of course the infamous soyface.
      If you don’t min-max your thumbnails, you’re leaving revenue money on the table. It’s an entire Darwinian ecosystem.
      1. Veritasium had good video on that.
        On the other hand – there are plugins now that replace those thumbnails or give proper names to videos. Dearrow and clickbait remover.
        there was time that yt could be explored – right now I just check on few channels I like.
  3. Well now… this is a channel I didn’t know I needed. Cool results. I have one of these blowers and it definitely is handy. I find the construction of the plane more interesting. Really cool to see how it goes together.
    1. If I were super rich, I’d give the company that makes them tooling to make a mirror image of that motor….same with copiers…that way mirror image toner tubes with different chirality can be scratch/bashed into warp nacelles.
      Same with Raptor engines for Starship….maybe they could be laid out like Sunflowers for easier fluid flow.
      Moller’s saucer flew higher than the Avrocar.
      I am hoping saucer craft could be updated.
      The Avrocar just needed a rubber skirt to be a hovercraft.
      I have even seen airplane designs with hovercraft tech instead of wheeled landing gear:
      (ACLS)
      https://militarymatters.online/forgotten-aircraft/an-14sh-my-hovercraft-is-full-of-aircraft/
