Investigating Whether Zener Diodes Work For ESD Protection
Sometimes the naming of parts in electronics can contribute to confusion about what they are good for, with the topic of Zener diodes in the context of fast surges like those from electrostatic discharge (ESD) being a good example. In a recent video by [BTT Lab] this particular question regarding Zener suitability for suppressing ESD is addressed, as compared to transient-voltage-suppression (TVS) diodes.
The main argument against using Zener diodes for ESD and similar surge suppression is that they react too slowly, which obviously gives said surge time to cause some real damage. This is where a special form of avalanche effect-based diodes called TVS diodes are recommended, as their response time is in the picoseconds rather than nanoseconds or slower as for Zener diodes.
Although this is technically true, as also pointed out in the video, a Zener diode also uses the avalanche effect, with the diode starting off conducting in the reverse direction using the Zener effect before transitioning to the much faster avalanche effect. The transition point is hereby determined by how heavily the p-n junction is doped, making effectively all Zener diodes also avalanche diodes.
TVS diodes consequently are basically Zener diodes that are optimized for a very early transition to said avalanche effect. They are also generally larger than typical Zener diodes as they generate a lot of internal thermal energy while in reverse conducting mode, which has to be contained and shed without causing permanent damage.
The short version is thus that diodes marked as ‘TVS’ are the best choice for surge protection, while those marked as ‘Zener’ are best used for voltage clamping, reference voltages and all other typical Zener diode things.
14 thoughts on “Investigating Whether Zener Diodes Work For ESD Protection”
  1. Ii learned to always carry a spare Lucas zener diode for my 1968 Triumph Bonneville motorcycle. It had a sizable aluminium heat sink but the zener was the weak link of the electrical system.
  2. I’ve used zener diodes on the gates of mosfets by having them soldered directly to them. This is useful when prototyping on breadboards. Keeps stray charges from building up on the gates and causing damage.
      1. Except BSS138K may or may not have protective diodes depending if you buy them for example from Onsemi or Diodes. So be careful when buying alternatives.
    1. This is a bad idea as the small loop closed by junction capacitance and lead inductance causes oscillation in the mid 100s MHz range, in linear condition or switching during commutation. (Internal zeners have negligible stray inductance.) Simple fix is a ferrite bead on the gate lead, inside of the zener.
  3. The TL;DR of this is “read the datasheet”, which unfortunately seems to result in the same result the vast majority of the time. Tangentially related, my favorite plea to end-users of all kinds(especially YOU, engineers): RTFM.
    1. Sometimes the secret to being a good engineer (or all-around competent person) is to be one of the few who reads the datasheet. It’s easy, most just don’t do it
      1. Or often CAN’T do it, at least as a small shop or individual as they are not a billion dollar company able to dangle huge orders and thus peel the real datasheet out of the company that holds the good stuff close to its chest.
    2. Nope. I won’t read the manual. If I can accidentally break it by using it as a person who maintains decades old equipment without any issue, it was probably designed wrong.
  4. The problem with a Z-diode is the increased gate capacity and that this diode is a bit slowly, but TVS diodes have much higher capacity. If you want it fast, then you simply use an ordinary diode and a charged capacitor which has a Z-diode in parallel. The energy can flow pretty fast into this capacitor and the Z-diode has time to destroy this energy which is inside of this capacitor.
