ToothPaste Goes Where Your Password Manager Doesn’t
One of the easiest ways of improving security and privacy when using the Internet, and computers in general, is to use strong passwords unique to each site or service. A password manager makes this easy on your phone or computer, but what if you’re in a situation where you can’t install any software on the device you’re logging into? In that case, maybe it’s time to get out the Toothpaste.
The way this creation from [brisk4t] works is that an ESP32-S3 is programmed to act as a keyboard and mouse for any computer it’s plugged into. From there, it connects over an encrypted WEB-BLE connection to another device like a laptop or smartphone. This second device can send text to the ESP32 acting using an extension for Chromium-based browsers, and the ESP32 sends it over the USB connection as if it were nothing more than a standard keyboard. This is all done without having to install any apps or drivers on the target machine, since any machine in the last two or three decades can recognize a USB keyboard and mouse with no problem.
Not only does this allow for easy password input for awkward situations, this can also be used for BIOS where an app couldn’t be installed anyway, for air-gapped systems with no networking, or insecure systems the user doesn’t trust. If you don’t need quite as many bells and whistles, we’ve seen a similar technique pulled off with an ATtiny85.
21 thoughts on “ToothPaste Goes Where Your Password Manager Doesn’t”
    1. I think the idea is just to bring the password manager to a PC/device you cannot install it onto not to be perfectly secure. You could wind up with a keylogger or clipboard sniffer on your phone or any other device you use your password manager on too.
    2. The keystroke logger only steals one password, not the password securing your entire password database, which is what I face when I install 1Password browser extension (granting access to thousands of passwords) on my work computer so I can do some of my personal stuff like amazon password when my mother calls.
      It would work well for IT, where they go to work on a random person’s PC. They don’t necessarily want to or even have the ability to log in as themselves fully.
      I can see uses for it, but nothing is a cure-all; there is no absolute fix for every situation.
  1. I have a workflow for this that doesn’t involve any custom hardware. You just need a barcode scanner and a local QR code generator. Most USB 2D barcode scanners just emulate a keyboard and type what they see so:
    1. Plug barcode scanner into locked down machine.
    2. Copy/paste the password you want to type into the QR generator.
    3. Scan the temporary QR code.
    1. Is that a barcode scanner in your pocket or are you just happy to see me? Also, anyone who sees the QR code now has your password. That is just the post-it under the keyboard with extra steps and no more secure.
      1. The barcode can be generated and displayed on your mobile device, which also has your password manager. Bonus points if the password manager has a built in feature to generate QR codes.
    1. BLE is just a transport in this case, each packet is signed with AES-256-GCM. It does add latency but it certainly isn’t insecure. The ECDH keys are on a secure element on the hardware side and locked with a password on the WEB-BLE transmitter side.
        1. What’s meant is that this is acts as a USB keyboard (same as the USB Yubikey OTP devices), so it can type passwords anywhere. The clever bit is that it’s controlled from your phone over bluetooth to the ESP32.
    1. The difference is that the Toothpaste stores the passwords securely on the device and you don’t need an app on the controlling device, as long as it has Chrome. So different architecture, but functional you’re right.
      I suppose it’s perfectly possible to write software for the LiliGo to work with Chrome and webBLE and then use passwords pasted from for instance you iCloud password manager.
  2. but what if you’re in a situation where you can’t install any software on the device you’re logging into?
    I’ll just use gpg manaully, instead of the script i usually use for convenience?
  3. SO, as many have pointed out, is it perfect? No. No approach is. However, I personally love the idea for some super niche things like phone driven Bluetooth keyboard for my locked down tv on my IOT network. Sure I could use the app offered by the tv to get the phone side keyboard, but this gets the ease of accessing while allowing for some neat alternatives to input control.
  4. I have a use-case for this – several, actually – but I don’t see hardware available, and I am way too old to build one myself (eyesight and hands don’t like SMC), and way too lazy anyway. I’d want the one with the security chip, so “just use any dev board” is out. I can’t seem to find a way to order it on PCBway. Did I just miss it? Or maybe the creator has a website or etsy or whatever and I just don’t see it.
