Although not very glamorous, wax motors are a fairly common type of linear actuator. They use the thermal response of waxes and the resulting volumetric expansion or reduction to create a relatively fast, smooth, and highly predictable actuator that can work for decades. They can often be found operating valves and things like the door mechanisms of washing machines. As [BubsBuilds] demonstrates in a recent video, you can even build your own wax motor for very precise control.
Here simple paraffin wax is used, which changes in volume by 1.15 times when it goes from solid to its molten state. Calling it a ‘waxtuator’, [BubsBuilds] characterized this expansion rate over the temperature range between solid and fully molten to make it a controllable actuator. In his experiments, a gap of less than 5 µm was maintained over twelve hours, showing how precise this device can be if you can control the temperature that the wax is kept at.
One major issue is the low conductivity of paraffin wax, which as some commentators remark can be solved by mixing something like fine copper particles into the wax to increase the thermal conductivity. In the shown implementation instead multiple channels in the aluminium block are used, which are melted by a TEC element.
The wax exerts pressure on a working fluid, which then pushes on a hydraulic cylinder that can be used for whatever precise linear actuating task has to be performed. Although initially water was used as a working fluid, this posed many issues with wax-water interface compatibility and vacuum degassing.
Although ethylene glycol makes for a better working fluid, this proved to be its own hassle. With the water-wax version a displacement sensor was thus used to measure and calibrate the whole setup. The electronics used to control the TEC in combination with the current temperature and displacement are a story in itself, but essential for making this device work.
While not something we often see tackled in the DIY space, we’ve covered a few teardowns of commercial units over the years.
My 1991 Ford Transit van has a wax driven actuator on the high pressure Bosch diesel pump. It’s used for cold starting. As the engine warms up it adjust the fuel pump.
Air-cooled VWs also, they have an air flap that is actuated by wax in a copper bellows. Aids warmup by blocking some of the air from the fan.
Many bathroom fans have a thermal actuator for opening the fan grille.
And most car water cooling thermostats are wax operated, so pretty common devices and usually very reliable.
Most are going electric these days though
But I thought they were glamorous…
Wax actuators were used on an underwater glider to operate a buoyancy control cylinder/piston. Once deep enough, and cold enough, the actuator expel water making the glider buoyant, once the glider was near the surface, and warm enough, the actuator would admit water, becoming negatively buoyant again and diving. Effectively giving the underwater vehicle long rang capability, without needing to carry lots of energy for propulsion.
Why are the comments now in italics?
Now the font is regular again… Weird, only this page had italic comments, the other pages I checked where regular.
I have no idea
Alas, poor IKEARUS, he flew too close to Brownian Motion and the wax melted. (sad face)
My parents had one connected to a greenhouse window. When I worked out for myself how it worked, and how elegant the mechanism is, it blew my tiny mind
Some carburetors have a wax motor for the automatic choke.
Speaking of automotive applications, I wonder if any of the various brake fluid formulations would be a good fit for the hydraulic aspect.
My clothes washing machine has a wax actuator to keep the door locked. Not exactly ‘fast’ when trying to unlock. It’s like waiting for wax to to solidify…
Now to use wax for 3D printing, as the next step in the lost wax pours.
Speaking of prints
https://techxplore.com/news/2026-11-3d-chain-mail-method-combines.html
