Pitting A Modern Chess Engine On A Pentium PC Against 1996’s Deep Blue
Although premature optimization can be a really bad thing, late optimization is sometimes unavoidable because we simply didn’t know about certain algorithms yet to massively improve the solving of a problem. When the 1990s was all about beating chess grandmasters at their game, IBM went so far as to build a the Deep Blue custom super computer for it. This is what [Nicholas Carlini] managed to effectively beat using a version of the Stockfish chess engine running on an era-appropriate Pentium PC.
A common way to measure one’s skill in chess involves the Elo rating system, named after chess master and physics professor [Arpad Elo]. As a relative system, it can be used to compare different players including chess engines against each other, with IBM’s Deep Blue scoring 2700, with the modern-day Stockfish engine hitting around 3700. This makes Stockfish statistically much more likely to win against a human chess grandmaster than Deep Blue, but also raises the question of how much of this advantage is due to Stockfish running on a much faster system.
To investigate the impact here, [Nicholas] used a Pentium Pro 200 MHz system with 64 MB of RAM (Fast Page or EDO SIMMs), which would have been a rather nice system for about 1995. Two chess engines were ported to this platform, being Crafty and Stockfish. Next both engines were tweaked with the help of an LLM coding bot to see what difference various compilation flags and algorithms would make.
Based on the results it would seem that the answer is ‘yes’: this 200 MHz Pentium Pro could have likely beaten even a chess grandmaster like [Kasparov] and Deep Blue in at least a few games, though without going back in time by about thirty years we’ll never know for certain.
Header: Wilfredor, CC0
27 thoughts on “Pitting A Modern Chess Engine On A Pentium PC Against 1996’s Deep Blue”
  1. (because who would want to buy a Pentium Pro when the better-in-almost-every-way Pentium MMX was now available for just $400?)
    AFAIK, gamers might have been been interested in faster VGA transfer rates via “Write Combining” feature of the CPU (ok, more like VBE/LFB than VGA).
    The Pentium Pro could use FastVid utility, while the Pentium MMX couldn’t yet.
    The Pentium II then combined best of both worlds, I think.
    Info: https://files.mpoli.fi/unpacked/hardware/misc/other/fastvid.zip/fastvid.txt
    But otherwise, the Pentium MMX was fine. It was Pentium derived, which made Pentium-aware software happy.
    It had more cache and some DOS games and multimedia titles supported it (ZSNES and Impulse Tracker come to mind).
    Windows wise, DirectX and Photoshop plug-ins had some early MMX support.
    MPEG software decoders, too. Win95 version of Xing MPEG Player, maybe?
    It also helped sound cards drivers and Winmodems, I guess.
    The matrix math extensions were well suited for DSP applications (digital signal processors).
    https://en.wikipedia.org/wiki/MMX_(instruction_set)
    1. Actaully not much. Wirth’s Law combined with algorithms and data structures 101 clearly limits what computer can perform within given unit of time. And in my opinion it’s actually good. Common people should not have access to powerful computers because those can be used to research weapons, explosives and other bad things. I feel like with Raspberry Pi we hit a good plateau of computing which should be allowed without license.
        1. It’s quite reasonable if we think of supercomputers, I think.
          Current supercomputers of nowadays, of course (not, say, a Cray II which is now as vintage as a C64 is).
          Because here we’re quickly entering the realm of research and military.
          I don’t think the commenter was thinking of a strong gaming PC, of course. That’s a civile application.
          1. Why would you guess what was he thinking of when he wrote:
            “I feel like with Raspberry Pi we hit a good plateau of computing which should be allowed without license”?
          2. @PPJ Well, he didn’t specify which model of Raspberry Pi.
            That leaves some room for interpretation. :)
      1. Wirth’s law is an observation tied to software bloat and programmer laziness. It is not a true limit on computing power as used by competent and dedicated programmers.
        Weapons and explosives have legitimate uses. Protection against attackers for weapons, mining and road building for explosives.
        The same crippling of computers to prevent weapons research would also cripple improved design for automobiles, bridges, and medicines. Quality games require high power computing.
        1. Gedankenexperiment. That “dual use” really is a problem, a paradoxon.
          Because it’s often being used as an excuse to not take responsibility.
          The technology itself is neither good nor bad, of course.
          So maybe the people are the problem, then. They might be careless.
          They perhaps must be educated, trained, conditioned, “programmed” to be ethical, to not misuse technology.
          Because “with great power comes great responsibility”.
          Let’s think of a digital booth camp, maybe, that shapes character.
          So they feel responsibility and guilt for their doing.
          You can’t give fire arms in the hand of toddlers, after all.
          Digital literacy is a key requirement in 21st century.
          Either people are responsible or they should have a legal guardian for the digital.
        2. I forgot. As a consequence, their equipment should be confiscadet if they misbehave.
          Same thing the FCC did for ages with illegal radio operators, basically.
          And after they obtain a valid license, they get their stuff back, of course.
          So that everything has its correctness.
      2. Limiting the power of single computers by law would only result in circumvention of and disrespect for law. Circumvention techniques include Beowulf systems, networking, and repurposing video cards, all already common.
        1. German here. Here in Europe, the gun laws are very restrictive and it works.
          Some restrictions are wise, it seems.
          I think it wouldn’t be so bad to consider people having to obtain a computer driving license, for example.:
          https://en.wikipedia.org/wiki/International_Certification_of_Digital_Literacy
          So they have to qualify themselves to properly operate a computer and know how to act responsible on the internet.
          After all, the “information super highway” has traffic rules, too!
          I don’t think that anyone should be “punished”, though.
          But maybe people shouldn’t be able to obtain a computer so easily without a license.
          People should have access to a training course/workshop to obtain that license, though.
          So they can learn and improve themselves.
          Perhaps that’s just a very German point of view or the view of a radio amateur, not sure.
          Where I live, certain amateur radio shops only sell radios and linear amps to people who can show a valid license/call sign.
          Relatives can buy gifts for their ham friend if the shop has the ham operator already registered or have a copy of the license.
          But of course, it’s always a matter of proportionality.
          Here in Germany, we still value cash because it means democracy, independence.
          Electronic cash allows tracking and spying and can lead to totalitarianism.
          And that shouldn’t happen again, of course.
      3. “I feel like with Raspberry Pi we hit a good plateau of computing which should be allowed without license.”
        Something like this I expect to hear from politicians on tech billionaire’s payroll because “they need more resources for their AI models or crypto mining” doesn’t sound right. Similar to the one that if someone doesn’t use computing power government should take it from him and give to someone else.
  2. Meanwhile an acquaintance of mine has implemented Stockfish inside an open weights Large Language Model, and it outperforms closed models from the big AI labs. We live in interesting times and it only takes months now for radical changes to occur in information technology and adjacent spaces.
    1. This doesn’t sound right to me. Stockfish is, AFAIK, a purely deterministic search engine. LLMs are probabilistic token guessers. When you say he implemented stockfish in an open weights LLM is this a harness like the added calculators (LLMs are terrible at simple math since they’re just guessing tokens) or is this something else? I don’t see why an LLM would help stockfish.
  3. If I remember correctly (and I may not, retirement approches :D ) these programs/machines were only able to beat grand masters for a few games in lightning chess. That’s not a small feat, mind you, but not as ground breaking as people seem to believe.
      1. Hey, that’s not a bad idea, actually.
        Because depending on how we look at it, a certain ELO level makes them “professionals”.
        So they need a license, just like professionals in certain sports or fishermen who go fishing.
        People who go to shooting range need a license, too, after all.
        Same goes to r/c fans who have to be registered in a club or need a license.
        If we think about it long enough, then it’s not that silly or farfetched anymore.
        There are pros and cons to anything, after all. :)
    1. The cited article did most of its testing at 1 second per move and 10 seconds per move. The wikipedia article on Deep Blue states that the contest with Kasparov used standard time limits (90 minutes for the first 40 moves.)
  4. One day computers might get so powerful that chess will become a solved problem, the entire game being represented by a state machine, as we might write a game of tic-tac-toe.
    1. Many years ago, a wise person (possibly I J Good, but I’m not sure) asked the following:
      “When a computer defeats the world champion at chess, should we think
      — less of humans,
      — more of computers, or
      — less of chess?”
  5. I think it’s funny and a little sad that the author of this article used an LLM (likely) to “port” Stockfish to a 32 bit CPU. It currently supports – you guessed it – 32 bit CPUs. It’ll compile and run just fine on a VAX, no porting needed.
