The Goat Emoji Is 100% Valid Machine Code, And It Doesn’t Stop There
Did you know emojis can be executables? Well, they are if you treat them like Intel 8088 or 8086 machine code, anyway. [GloriousCow] shared this clever revelation, demonstrating that executable programs could be created entirely from emojis. To really appreciate why, it’s necessary to take a small step back.
It all started when [GloriousCow] happened to notice, entirely by chance, that ๐Ÿ (the goat emoji) was F0 9F 90 90. Anyone familiar with x86 assembly language probably recognizes 90h as nop,ย  or null operation, or “spend a cycle doing nothing”. What about F0 and 9F? Together they are lock lahf (assert the bus lock signal then copy some status flags into register AH) which, on an 8088 and 8086, essentially does nothing.
This means the goat emoji (F0 9F 90 90) is 100% technically valid machine code. It doesn’t do anything, but here’s where it gets even more interesting.
A short string of emojis is machine code that writes HELLO (lower right) by writing directly to video memory.
There are loads of emojis, and manyย of them start with F0 9F followed by two more bytes, and many of those other two-byte combinations are surely also valid machine code. Could one create a meaningful executable program consisting entirely of emojis? The answer is yes, and [GloriousCow] crafted a simple Hello World program to demonstrate.
The simple program looks like this: ๐Ÿธโ˜บ๏ธ๐Ÿฐ๐ŸŽโ™๐Ÿ—ƒ๏ธ๐Ÿงฏ๐Ÿงฏ๐Ÿงฏ๐Ÿฎ๐Ÿ’—๐Ÿฆฎ๐Ÿชโ™๐Ÿฐ๐Ÿน๐Ÿ—ƒ๏ธ๐Ÿงฏ๐Ÿงฏ๐Ÿงฏ๐Ÿงฏ๐Ÿ’—๐Ÿช—๐Ÿงฏ๐Ÿ˜—๐Ÿงฎ๐Ÿซช๐Ÿ˜—๐Ÿงฎ๐Ÿ˜—๐Ÿฎ๐Ÿ˜ช๐Ÿ˜”โญ. Save that string of emojis to a file, give it a .com extension, and run it in DOSBox with CPU type set to 8086. It’ll printย HELLO at the bottom-right of the screen by writing directly to video memory.
There are loads more details on the original blog post, including plenty of resources and tips for writing your own executables with emojis. There’s also a much more involved VGA demo program made from emojis, so give it a look.
Some of you may be aware that ASCII characters can also be used in a similar way (and more flexibly, since they are not four-byte combinations like emojis). This was used in BASIC programs as a way to cleverly embed machine code in things like REM statements, creating odd-looking code that did things in BASIC that shouldn’t have been possible.
Making Xibalba 64, A New N64 Release In 2026
[Dominic Szablewski] created something that we don’t see every day: a no-kidding new physical Nintendo 64 game for sale, complete with cartridge, manual, and box art. He wrote about what it was like to make Xibalba 64, a 3D FPS game built using his own game engine. It even supports two-player couch co-op and four-player deathmatch.
The N64 was a groundbreaking console that brought analog controls and fully 3D game worlds to mainstream console gaming. Architecture-wise it has its share of quirks, including a tiny (4 kB!) amount of texture memory to go around all that fancy 3D content.
Xibalba was originally a demo game for [Dominic]’s MIT-licensed game engine, high_impact. Turning it into a full-fledged title for the N64 meant revisiting all sorts of things from level and gameplay design to sound and music. [Dominic] talks about it all, including the fact that his engine is technically for 2D content but he makes it work for the 3D game by ensuring levels have no elevation. Since levels are flat, the engine never has to deal with a dimension beyond its understanding. Xibalba 64 even maintains a stable 60 frames per second, dipping somewhat only in four-player split-screen.
The N64 still gets a lot of action from dedicated enthusiasts, and there’s no need to start from scratch if you find yourself with a retro gaming itch and a desire to push a vintage console in directions it never knew. For example, we’ve seen an open world game engine for the N64, complete with long drawing distances that didn’t seem possible on the hardware.
