Artemis II Rocket Was Powerful Enough To Disrupt GPS
Rockets certainly have a substantial impact if you ever see a launch in person. The noise, shock waves, and even heat can be awe-inspiring. What is less obvious are the impacts a launch has on our upper atmosphere, or “anthropogenic space weather” as the fancy scientists call it. A pre-print from a recent study on Artemis II’s impact on our atmosphere shows a shockingly wide range of effects.
As a whole, the impact on Artemis comes in waves. Each stage of the Space Launch System performs burns in different parts of the atmosphere, creating increasing ripples as the rocket moves through various layers. The first stage is the largest in terms of thrust, but has limited impact on the ionosphere because of how low it occurred. The 2nd and 3rd stages’ impact, however, was so large that it could’ve sustainably disrupted GPS signals at the time. Waves even traveled through the atmosphere across the entirety of North America in the form of gravity waves.
[Editor’s note: These are gravity waves, and not gravitational waves. These are waves in the ionosphere where the restorative force is gravity, in contrast to compression waves.]
These ionosphere “holes” might not be a major problem now, but it’s something to think about as we ramp up rocket production. While this research relied on thousands of sensors across the globe, that doesn’t mean you need the same budget to analyze the state of the ionosphere at home.
30 thoughts on “Artemis II Rocket Was Powerful Enough To Disrupt GPS”
  1. Perhaps by the time that the frequency of rocket launches is high enough to seriously disrupt Earth’s (global, not local) environment, they’ll be able to manufacture mass quantities of coherently arranged carbon nanotubes, and be building that space elevator.
    Or not…where’s my flying car? And what about controlled, power-producing fusion? :-)
    1. Commonwealth fusion is expected to achieve first spark on their prototype reactor next year (2027, with some estimates putting it at late 2026). They’re so certain of the results that they’ve purchased land for their first commercial reactor, and are expected to break ground in 2027.
      It’s based on a breakthrough in superconductor technology (around 2011, IIRC), which allows for a larger containment field, and energy output is proportional to the 4th power of that field. You can find YouTube videos explaining all of this.
      https://cfs.energy/
      Flying cars are here, there are something like 7 models currently for sale. Tesla recently demo’ed their version in a completely awesome video. It’s not flying as in “fly to the grocery store”, but impressive nonetheless:
      https://www.youtube.com/watch?v=3T3F-LNnfMI
      There’s also the Jetson personal aerial vehicle, although I don’t think it’s legal on any streets anywhere.
      https://jetson.com/
      Apropos of nothing, I follow several technological innovations. Another one is Verdox, which has a method for pulling CO2 from the atmosphere using electrolysis. Conceptually it works sort of like an oxygen concentrators, except it uses electrolysis and not absorption.
      https://www.verdox.com/
      Lots of interesting technologies are on the near horizon. We’ve almost eradicated polio worldwide, and I’m waiting for the US to start eradicating anopheles mosquitos (an invasive species).
        1. Always has been, fines etc are simply factored in as a cost of doing business.
          The Pinto in the 70’s is the classic example; cost of recalls > cost of wrongful death lawsuits, eh, let ’em fry.
          One solution is to fine the company plus fine & jail the decision makers, but oddly enough that’s seen as a bad idea.
    1. It didn’t come close to jamming the signal.
      Using the word “disrupt” seems to be rather hyperbolic in this instance too.
      “Disturb” might be more appropriate, but even that seems somewhat strong.
      The scientific accuracy of the hackaday summary is a tad suspect.
      The paper discusses using GPS ground station observations to measure the disruption of the ionosphere. The paper doesn’t classify the induced positional error that resulted from this.
      Based on rough analysis it’s in the decimeter-scale range.
      It would be interesting to take the same dataset and calculate out the induced error across the entire affected region.
      This article though? Hyperbole.
      1. Background info: The GPS signal relies on signals propagating at the speed of light, but this speed is variable in the atmosphere, mostly due to variations in moisture content.
        The receiver uses signals from multiple satellites to compensate for this variation.
        Putting stuff into the ionosphere changes it’s index of refraction slightly, which slows down the signal, which causes inaccuracies in the calculated location.
        Note that GPS is only accurate to 3 to 5 meters anyway.
        1. The speed varies mostly due to the electron content in the atmosphere. They actually list predictions for ionospheric corrections ahead of time because changes are slow, but stuff like this is unexpected and throws off the corrections.
          1. Submillimeter GPS is really only relative: as in, you know the object is fixed and you’re determining submillimeter changes.
            Absolute positioning with GPS also does have long tails due to stuff like this, so you absolutely can get meter-scale shifts.
  2. The preprint talked about characterization of TEC (Total Electron Concentration) of the ionosphere using GPS, but nowhere did it mention or imply that there was any disruption.
    I wonder what effect that the localized injection of water vapor into the lower atmosphere has on tropospheric signal propagation. Certain locations under launch plume might be affected by a thousand tons of water suddenly appearing, and it’d be interesting to know by how much.
    1. Does it talk any about natural phenomena causing similar disruptions? I can’t imagine a hundred meters of rocket going through the atmospheric boundary once causes more disruption than say a tropical storm or a meteor. That doesn’t ever mess with global GPS. What is the basis of the assertion that this “could be able to” disrupt GPS? The preprint seems pretty light on those specifics, maybe I missed something.
  3. A large rocket launch releases the equivalent acoustic energy of several kilotons of TNT (albeit spread over a few minutes), readily detectable globally by the many infrasound monitoring stations. e.g. https://www.researchgate.net/publication/385937537_Infrasound_signatures_from_powerful_rocket_launches_for_space_missions
    and https://conferences.ctbto.org/event/27/contributions/5409/attachments/2699/5052/241107_Pilger_Hupe_ITW_RocketInfrasound.pdf
  4. “The 2nd and 3rd stages’ impact, however, was so large that it could’ve sustainably disrupted GPS signals at the time”
    No, not even close.
    Hackaday needs to increase their editorial oversight and their comment moderation. Having the article remain while the comments adding substantial context be deleted is a substantial disservice in the case of this article.
    1. Do meteors crashing through the atmosphere routinely disrupt GPS and I’m just unaware of this, or maybe there’s some system for routing around the affected regions? I searched the preprint for any mention of natural atmosphere-crossing objects and their effects but found none.
      What does “could’ve” mean in this context anyway?
  5. The headline grabs attention with a technicality, but misses the scale and the safeguards. The rocket did punch a hole in the ionosphere, and ground-based stations did record the blip. But calling it a “GPS disruption” makes it sound like an outage or a failure, when it’s really just a localized blip that the network shrugged off instantly.
  6. Kudos to Ian Bos for including that note on the difference between gravity and gravitational waves.
    So often people get confused by that (understandably so) and then start to repeat their erroneous interpretation all over the place.
    1. obviously there were problems with the comment system … maybe we should collect more data before pointing someone out
      (coincidentally using this comment to try out the new comment system, so this comment may look odd)
