Play Text Adventures On An E-Paper Handheld
A landscape-oriented e-paper display in a clear enclosure. A blue-ish LED glows on the right below the black rotary encoder knob.
Choose your own adventure books were one of the first media to become gamified in the computer era, and [Jeremy Ngai] wanted to bridge the experience further with an e-paper handheld adventure game.
With a 2.9″ e-paper screen, rotary encoder, and RGB LED that can provide mood lighting for the story, it can provide an estimated 20 hours of entertainment per charge, which is a lot better than the Game Gear this author had as a child. As with many projects we see these days, a custom PCB and 3D printed enclosure give the build a professional polish.
Upon the first boot, you setup the WiFi like on other ESP32 devices through a captive portal. Once connected to the internet, the device contacts Gemini for a generated choose-your-own-adventure story. We think it would be interesting to modify the code to connect to a library of human-written stories, perhaps a port of Zork? Everything you’d need to build your own is on GitHub.
If you want to play games that are easy on the eyes, how about an EInk Gameboy or another one with a separate screen and controller.
6 thoughts on “Play Text Adventures On An E-Paper Handheld”
  1. It uses Gemini for generating the story and the options. I don’t mind it, it’s the only way to go with only a single rotary encoder as the input method
    I myself enjoy Z machine games a lot more but they require a full keyboard
    1. You don’t really need a full keyboard as long as you can generate (without AI) all possible input combinations. The rotary encoder could easily be used to select a valid commands, select valid parameters, etc. Just one or two additional buttons would suffice for “Enter” and “Back/Cancel”.
      Just look at the original Nintendo Game Boy which only has a D-Pad and two buttons (A/B). It might not be the most pleasant interface for a text-input heavy game, but it can be done. There are other ways you could present a “virtual keyboard” without painfully selecting one character at a time from a grid, that’s just the least complicated (for the user).
      E.g select a subset of the alphabet in whatever the current case (lower/upper is)
      6 groups of 4, 1 group of 3: ABCD, EFGH, IJKL, MNOP, QRST, TUVW, XYZ
      4 groups of 6, 1 group of 2: ABCDEF, GHIJKL, MNOPQR, STUVWX, YZ
      It’s even easier to skip on direct entry and just select from a group of valid inputs. E.g. grouping commands into sub-groups and items by type.
      Might not be the prettiest, but Powder ( a rogue-like for the GB / GBA) has menu selections for many of the game actions.
  2. The project is well done, but, it’s really a text-only version of a renpy-style game… Created on the fly by the Gemini “AI”… More hunt the pixel than interactive fiction. If that’s your thing then OK, but, you’re never going to port a classic like Zork to this. Activision tried something similar with “Return To Zork” in this kind of format. And it sucked bilge water.
