Phone connected to the DIY LTE network playing a YouTube video, with antennas in the background
Building Your Own 4G LTE Base Station
We’ve seen quite a few DIY 2G networks over the years, but the 4G field has been relatively barren. Turns out, there’s an open source suite called srsRAN that lets you use an SDR for setting up an LTE network, and recently, we’ve found a blog post from [MaFrance351] (Google Translate) that teaches you everything you could need to know if you ever wanted to launch a LTE network for your personal research purposes.
For a start, you want a reasonably powerful computer, a transmit-capable full-duplex software defined radio (SDR), suitable antennas, some programmable SIM cards, and a few other bits and pieces like SIM card programmers and LTE-capable smartphones for testing purposes. Get your hardware ready and strap in, as [MaFrance351] guides you through setting up your own base station, with extreme amounts of detail outlining anything you could get caught up on.
Continue reading “Building Your Own 4G LTE Base Station”
Revive That Old Analog Cell Phone With SDR
With the latest and greatest 5G cellular networks right around the corner, it can be difficult to believe that it wasn’t so long ago that cell phones relied on analog networks. They aren’t used anymore, but it might only take a visit to a swap meet or flea market to get your hands on some of this vintage hardware. Of course these phones of a bygone era aren’t just impractical due to their monstrous size compared to modern gear, but because analog cell networks have long since gone the way of the floppy disk.
But thanks to the efforts of [Andreas Eversberg] those antique cell phones may live again, even if it’s only within the radius of your local hackerspace. His software allows the user to create a functioning analog base station for several retro phone networks used in Europe and the United States, such as AMPS, TACS, NMT, Radiocom, and C450. You can go the old school route and do it with sound cards and physical radios, or you can fully embrace the 21st century and do it all through a Software Defined Radio (SDR); in either event, calls to the base station and even between multiple mobile devices is possible with relatively inexpensive hardware.
[Andreas] has put together exceptional documentation for this project, which starts with a walk through on how you can setup your DIY cell “tower” with traditional radios. He explains that amateur radios are a viable option for most of the frequencies used, and that he had early success with modifying second-hand taxi radios. He even mentions that the popular BaoFeng handheld radios can be used in a pinch, though not all the protocols will work due to distortion in the radio.
If you want to take the easy way out, [Andreas] also explains how to replace the radios with a single SDR device. This greatly simplifies the installation, and turns a whole bench full of radios and wires into something you can carry around in your pack if you were so inclined. His software has specific options to use the LimeSDR and LimeSDR-Mini, but you should be able to use other devices with a bit of experimentation.
We’ve previously reviewed the LimeSDR-Mini hardware, as well as covered its use in setting up DIY GSM networks.
Building An Advanced Mobile Phone Service (AMPS) Base Station
Remember the early days of cellphones and carphones when they were super-bulky and all the rage? Those early handsets used analog technology for communications in a protocol called Advanced Mobile Phone Service (AMPS). As more customers flocked to wireless providers, networks were transitioned over to digital phones in order to save bandwidth. Some places still support AMPS but it has rapidly gone the way of the Dodo. But a few years back [Mark Atherton] got his hands on some old hardware, including a bag-phone and some test equipment, and set out to build a base station that can control AMPS handsets. In short, he’s creating his own analog cellphone tower. There’s a wealth of information on his page. The writeup comes out as a mix of protocol and electronic resources he scavenged across the net, as well as a work log serving as a testament to his successes and failures. He did his experiments in New Zealand, so if you’re thinking of undertaking this make sure to research your local radio regulations first.
[Thanks J]
