A Classic TV Trope For An Escape Room
No spooky mansion is complete without a secret passage accessed through a book shelf — or so Hollywood has taught us. What works as a cliché in movies works equally well in an escape room, and whenever there’s escape rooms paired with technology, [Alastair Aitchison] isn’t far. His latest creation: you guessed it, is a secret bookcase door.
For this tutorial, he took a regular book shelf and mounted it onto a wooden door, with the door itself functioning as the shelf’s back panel, and using the door hinges as primary moving mechanism. Knowing how heavy it would become once it’s filled with books, he added some caster wheels hidden in the bottom as support. As for the (un)locking mechanism, [Alastair] did consider a mechanical lock attached on the door’s back side, pulled by a wire attached to a book. But with safety as one of his main concerns, he wanted to keep the risk of anyone getting locked in without an emergency exit at a minimum. A fail-safe magnetic lock hooked up to an Arduino, along with a kill switch served as solution instead.
Since his main target is an escape room, using an Arduino allows also for a whole lot more variety of integrating the secret door into its puzzles, as well as ways to actually unlock it. How about by solving a Rubik’s Cube or with the right touch on a plasma globe?
Continue reading “A Classic TV Trope For An Escape Room” →
Secret Outside Door
Secret Door Is Now Not So Secret
You’d be hard pressed to find someone who didn’t think secret doors are cool. They can come in many different forms, a built-in book case, a fake fireplace or even the rudimentary trap door under the rug. [oggfaba] has created a sweet secret door to enter his house. It is so well done there is no need for an architectural detail to hide it, it’s right there in plain sight.
To the unknowing onlooker, the rear of the house looks as any should with a window and water spigot. That water spigot is actually non-functional and acts as a door knob. The door-part of this secret door is just a standard fiberglass exterior door fitted with an electronic deadbolt and covered in exterior siding painted to match the rest of the house.
There are two methods to lock and unlock the door. There is a fob that can remotely unlock the installed deadbolt. There is also a keypad hidden under its own mini-secret door disguised as house siding material. There was no hacking involved with the deadbolt, keypad or remote. The Morning Industry QF-01SN deadbolt is available off the shelf with both unlocking options.
Continue reading “Secret Door Is Now Not So Secret” →
