Sail Virtually Aboard The “Itanic” With IA-64 Emulator
Intel’s Itanium architecture was an interesting experiment, but it has gone down in history as one of the chip giant’s bigger flops, so much so that it earned the name “Itanic” in the tech press. This is perhaps unfair, considering it did limp on until a quiet EOL in 2020. We didn’t know anyone missed it, but perhaps it was more the technical challenge than nostalgia for obsolete server hardware that led [Yufeng Gao] and [gdwnldsKSC] to spin up an instruction-set translator for the late, lamented, IA-64 architecture.
Note that it’s very much in alpha, version 0.1, so don’t expect all the things. Neither HP-UX and OpenVMS will boot, which is a pity since Itanium’s great success was arguably winning those OSes and thereby killing the bespoke architectures HP and DEC had at the time. Gentoo can get to a shell, as long as you use Kernel 6.6 or older, and Windows Server 2003 and XP-64 both apparently boot.
It’s not incredibly performant, with 486-level speeds when running on Ryzen 5000 series hardware, but then, it is a 64-bit hardware being emulated here, and pretty weird hardware at that. Itanium’s Very Long Word Instruction architecture was notoriously hard to program well. Specifically, it was hard to compile optimized programs for, so we expect optimizing an emulator is going to be similarly difficult. That’s why this is so impressive, even at this early stage.
The late, unlamented Itanium is probably one of the few systems not in the Virtual OS Museum, but perhaps eventually this project will change that.
via Raymii.org
Itanium: The Great X86 Replacement That Never Was
Itanium was once meant to be the next step in computing, to compete with the likes of IBM, Sun and DEC, but also for Intel to have an architecture that couldn’t be taken from it, as the PC was from IBM by its clones. Today, however, Itanium is a relic of the past. [Asianometry] tells us the story of Itanium.
By the ’90s, servers were an established market dominated by RISC architectures and Unix-like operating systems. Intel wanted to compete in this market, due in part to worries of losing control over x86. So, when Hewlett Packard came to Intel in late ’93, Intel eventually agreed to collaborate on a new project in EPIC (Explicitly Parallel Instruction Computing).
Continue reading “Itanium: The Great X86 Replacement That Never Was” →
