With the days of dial-up and pitiful 2G data connections long behind most of us, it would seem tempting to stop caring about how much data an end-user is expected to suck down that big and wide broadband tube. This is a problem if your respective tube happens to be a thin straw and you’re located in a base somewhere in the Antarctic. Take it from [Paul Coldren], who was stationed at a number of Antarctic research stations as an IT specialist for a total of 14.5 months starting in August of 2022.
![Prepare for hours of pain and retrying downloads. (Credit: Paul Coldren]](https://hackaday.com/wp-content/uploads/2025/09/engineering-for-slow-internet-icon.png?w=400)
As [Paul] describes, the main access to the Internet at these bases is via satellite internet, which effectively are just relay stations. With over a thousand people at a station like McMurdo at certain parts of the season, internet bandwidth is a precious commodity and latency is understandably high.
This low bandwidth scenario led to highly aggravating scenarios, such as when a web app would time out on [Paul] while downloading a 20 MB JavaScript file, simply because things were going too slow. Upon timing out, it would wipe the cache, redirect to an error page and have [Paul] retry and retry to try to squeeze within the timeout window. Instead of just letting the download complete in ~15 minutes, it would take nearly half an hour this way, just so that [Paul] could send a few kB worth of text in a messaging app.
In addition to these artificial timeouts – despite continuing download progress – there’s also the issue of self-updating apps, with a downloader that does not allow you to schedule, pause, resume or do anything else that’d make downloading that massive update somewhat feasible. Another thing here is distributed downloads, such as when hundreds of people at said Antarctic station are all trying to update MacOS simultaneously. Here [Paul] ended up just – painfully and slowly – downloading the entire 12 GB MacOS ISO to distribute it across the station, but a Mac might still try to download a few GB of updates regardless.
Continue reading “Engineering For Slow Internet Even When Not Stuck In Antarctica”
