Happy Birthday 6502
The MOS Technology 6502 is a microprocessor which casts a long shadow over the world of computing. Many of you will know it as the beating heart of so many famous 8-bit machines from the likes of Commodore, Apple, Acorn, and more, and it has retained enough success for a version to remain in production today. It’s still a surprise though, to note that this part is now fifty years old. Though there are several contenders for its birthday, the first adverts for it were in print by July 1975, and the first customers bought their chips in September of that year. It’s thus only fitting that in August 2025, we give this processor a retrospective.
The Moment Motorola Never Really Recovered From
A double page advert for the MOS 6501 and 6502, advertising its low cost and high performance.
The advert that started it all. MOS Technology, Public domain.
The story of the 6502’s conception is a fascinating tale of how the giants of the early mocroprocessor industry set about grappling with these new machines. In the earlier half of the 1970s, Chuck Peddle worked for Motorola, whose 6800 microprocessor reached the market in 1974. The 6800 was for its time complex, expensive, and difficult to manufacture, and Peddle’s response to this was a far simpler device with a slimmed-down instruction set that his contact with customers had convinced him the market was looking for: the 6502.
There’s a tale of Motorola officially ordering him to stop working on this idea, something he would later assert as such an abandonment of the technology that he could claim the IP for himself. Accompanied by a group of his Motorola 6800 colleagues, in the summer of 1974 he jumped ship for MOS Technology to pursue the design. What first emerged was the 6501, a chip pin-compatible with the 6800, followed soon after by the 6502, with the same core, but with an on-board clock oscillator. Continue reading “Happy Birthday 6502”
ESP8266 As A Tape Drive
1976 was the year the Apple I was released, one of several computers based on the MOS 6502 chip. MOS itself released the KIM-1 (Keyboard Input Monitor) initially to demonstrate the power of the chip. The single board computer had two connectors on it, one of which could be used for a tape recorder for long-term storage. When [Willem Aandewiel] went to the Apple Museum Nederland in 2016, he saw one and felt nostalgic for his youth. He was able to get a replica, the microKIM, and build it but he wanted to use new technology to interface with this old technology, so he decided to use an ESP8266 as a solid state tape recorder.
One of the reasons the KIM-1 was so popular when it was released was that there was lots of documentation available. [Willem] used this documentation to figure out how the KIM-1 saves data to the recording device. An ATTiny85 is used to decode the pulse stream that the KIM-1 sends when saving because the timing was too tight to both “listen” and decode the bits as well as convert and store them. For loading programs, the data can be sent digitally as 1’s and 0’s to the KIM-1. This means that the ATTiny is only used for decoding and doesn’t have to re-encode the data.  Because of this, saving is slow, but loading is very quick.
To complete the project, [Willem] added four buttons, one each for rewind, record, play and fast-forward, and a screen so you can see which program is currently selected and can go from one program to another. As a nice throwback touch, record and play have to be pressed at the same time when saving. For more 6502 projects, check out this 6502 based DIY computer, or this 6502 built from discrete parts.
Continue reading “ESP8266 As A Tape Drive”
How To Debug A Faulty Memory Board
ram
While this is not exactly a hack or a fail, it definitely is an inspiring example on how to debug a faulty card.
[Quinn] is one of the very few hobbyists out there that designed her own 6502 based computer. For the young readers of Hackaday, the MOS 6502 was introduced in 1975 and has been used in the Aple // line, the Commodore 64, the Vic-20, the Atari computers, the Nintendo Enterntainment System and others.
[Quinn]’s homemade new RAM board had been working for many weeks until it started to show some weaknesses by only sporadically passing the boot RAM test. Assuming the RAM was the problem, she started by making a more advanced memory test, which showed errors at random addresses.
She didn’t have any more of the same memory chips on hand which could be used with a fresh PCB. Determined to power through the issue, she etched a new board with a new memory design. Unfortunately it also gave memory errors at boot. Only one culprit was left, which is shown in the picture above. It’s a small sizing error in the board artwork which was just enough to cause a misalignment on the connector.
The article contains many details about her debugging process, so it definitely is worth the read.
