Ask Hackaday: How Do You Detect Hidden Cameras?
The BBC recently published an exposé revealing that some Chinese subscription sites charge for access to their network of hundreds of hidden cameras in hotel rooms. Of course, this is presumably without the consent of the hotel management and probably isn’t specifically a problem in China. After all, cameras can now be very tiny, so it is extremely easy to rent a hotel room or a vacation rental and bug it. This is illegal, China has laws against spy cameras, and hotels are required to check for them, the BBC notes. However, there is a problem: At least one camera found didn’t show up on conventional camera detectors. So we wanted to ask you, Hackaday: How do you detect hidden cameras?
How it Works
Commercial detectors typically use one of two techniques. It is easy to scan for RF signals, and if the camera is emitting WiFi or another frequency you expect cameras to use, that works. But it also misses plenty. A camera might be hardwired, for example. Or store data on an SD card for later. If you have a camera that transmits on a strange frequency, you won’t find it. Or you could hide the camera near something else that transmits. So if your scanner shows a lot of RF around a WiFi router, you won’t be able to figure out that it is actually the router and a small camera.
Continue reading “Ask Hackaday: How Do You Detect Hidden Cameras?”
A Wireless Webcam Without A Cumbersome Cloud Service
After a friend bought a nannycam that required the use of a cloud service to make the device useful,  [Martin Caarels] thought to himself — as he puts it — ”I can probably do this with a Raspberry Pi!
Altogether, [Caarels] gathered together a 4000mAh battery, a Raspberry Pi 3 with a micro SD card for storage, a Logitech c270 webcam, and the critical component to bind this project together: an elastic band. Once he had downloaded and set up Raspbian Stretch Lite on the SD card, he popped it into the Pi and connected it to the network via a cable. From there, he had to ssh into the Pi to get its IP so he could have it hop onto the WiFi.
Now that he effectively had a wireless webcam, it was time to turn it into a proper security camera.
Continue reading “A Wireless Webcam Without A Cumbersome Cloud Service”
