[Luca Dentella] recently encountered a toy, which was programmed to read different stories aloud based on the figurine placed on top. It inspired him to build an audio device using the same concept, only with music instead of children’s stories.
The NFC Music Player very much does what it says on the tin. Present it with an NFC card, and it will play the relevant music in turn. An ESP32 WROOM-32E lives at the heart of the build, which is hooked up over I2S with a MAX98357A Class D amplifier for audio output. There’s also an SD card slot for storing all the necessary MP3s, and a PN532 NFC reader for reading the flash cards that activate the various songs. Everything is laced up inside a simple 3D-printed enclosure with a 3-watt full range speaker pumping out the tunes.
It’s an easy build, and a fun one at that—there’s something satisfying about tossing a flash card at a box to trigger a song. Files are on Github for the curious. We’ve featured similar projects before, like the Yaydio—a fun NFC music player for kids. Video after the break.
