A 3D Printed Pixel Clock, With A Twist
The availability of cheap addressable RGB LED strips has been a huge boon for hardware hackers, as it makes many projects far more accessible. This usually requires a lot of snipping, followed by the monotony of connecting up a bunch of fiddly jumper wires, but that’s still generally preferable to having to solder all of the LEDs individually.
But what if you didn’t even have to do that? That was the goal of the brilliantly designed PixelClock by [Dom Dominici] — by carefully weaving a continuous 2.5 meter strip of WS2812B LEDs through its 3D printed structure, you can create a 7×19 display without any tedious manual work. Technically you do “waste” a few LEDs in the process since they’ll be on the inside of the folded strip, but that’s literally and figuratively a small price to pay for the added convenience offered by this approach.
We saw this one in person during Hackaday Supercon, and [Dom] tells us the whole idea was to make it as accessible as possible for new players. While we know there’s plenty of readers who actually enjoy the process of stripping and soldering wires, that’s not necessarily true for the average person. Of course the builder still needs to connect the end of the LED strip to the ESP32 WROOM development board that controls it, but that’s still a lot less intimating of a prospect for somebody that doesn’t breathe solder smoke on the regular.
The PixelClock is configured via a web interface running on the ESP32, so there’s nothing you need to install on your phone or computer to get it working. You can even install the firmware via WebSerial, making the build process that much friendlier.
One of the things we liked the most about the design is the printed diffuser — it might look like paper or some kind of opaque acrylic, but in actuality it’s just a couple layers of plastic. You can easily swap filament during the print to come up with different color variations, and for those that are comfortable in CAD, creating custom “pixels” is as easy as changing the shape of the individual LED compartments. Even in the bright Pasadena sunlight, the effect was impressive.
If you don’t mind cobbling together LED strips, this concept can be applied at a much larger scale.
Get Your Monitor Transmitting VHF With A Browser Tool
If you’re intending to transmit on the VHF band, you’re probably going to reach for a handheld or some kind of rackmount rig in your ham shack. But you needn’t bother with all that complexity, when you can use the computer on your desk to spit out such signals using a simple browser tool from [Efe].
The concept is straightforward—[Efe]’s tool manipulates pixel clocks in order to create spurious transmissions from your computer’s graphics hardware. The math pencils out pretty easily—multiply the horizontal resolution by the vertical resolution by the refresh rate, while paying attention to the precise timing of the video standard your monitor is using, and you’ve got your transmission frequency. For example, for a screen displaying 1080p at 60 Hz, with the CEA-861 timing standard, your horizontal and vertical resolutions are 2200 and 1125 respectively when paying attention to the requisite blanking intervals. Multiply those by 60 hz, and you’ll find you’re creating a signal at 148.500 MHz. Leverage this by displaying the right pattern of black and white pixels to maximise changes in voltage state on the HDMI or DisplayPort lines, and you might create a strong enough signal that you can actually pick something up. [Efe] created a tool to display these patterns to send simple Morse code messages over VHF just by flickering your screen just right.
You can test the transmitter tool for yourself here, right in your browser. You’ll want to hold your radio’s antenna nice and close to the monitor to see if you can pick up much of a signal. After all, the monitor, connectors, and cable are all built to optimize for clear signal transmission to the display, while preventing signal from leaking out to interfere with surrounding equipment.
Of course, a fair warning—you’re not supposed to intentionally transmit on bands you’re not licensed for, even if it’s incredibly weak and unlikely for anyone else to notice in a scenario like this. Still, it’s an interesting project that shows you just how electromagnetic interference can leak out of just about anything under the right conditions.
