Parabolic reflectors are pretty handy devices. Whether you’re building a microwave antenna or a long-distance directional microphone, suitable commercial dishes aren’t that hard to come by. But a big, shiny mirror for your solar death-ray needs is another matter, which is where this pressure-formed space blanket mirror might come in handy.
Pressure-forming was a great choice for [NighthawkInLight]’s mirror. We’ve covered pressure-formed plastic domes before, and this process is similar. A sheet of PVC with a recessed air fitting forms the platen. The metallized Mylar space blanket, stretched across a wooden frame to pull out the wrinkles and folds, is applied to a circle of epoxy on the platen. After curing, a few puffs with a bicycle tire pump forms the curve and stretches the film even smoother. [NighthawkInLight]’s first attempt at supporting the film with spray foam insulation was a bust, but the later attempt with fiberglass mesh worked great. A little edge support for the resulting shiny taco shell and the mirror was capable of the required degree of destructive potential.
We doubt this process can be optimized enough to produce astronomy-grade mirrors for visible light, but it still has a lot of potential applications. Maybe a fiberglass radio astronomy dish could be pressure-formed directly with a rig like this?
