It’s not every day we hear of a new space propulsion method. Even rarer to hear of one that actually seems halfway practical. Yet that’s what we have in the case of TFINER, a proposal by [James A. Bickford] we found summarized on Centauri Dreams by [Paul Gilster] .
TFINER stands for Thin-Film Nuclear Engine Rocket Engine, and it’s a hoot. The word “rocket” is in the name, so you know there’s got to be some reaction mass, but this thing looks more like a solar sail. The secret is that the “sail” is the rocket: as the name implies, it hosts a thin film of nuclear materialwhose decay products provide the reaction mass. (In the Phase I study for NASA’s Innovative Advanced Concepts office (NIAC), it’s alpha particles from Thorium-228 or Radium-228.) Alpha particles go pretty quick (about 5% c for these isotopes), so the ISP on this thing is amazing. (1.81 million seconds!) Continue reading “TFINER Is An Atompunk Solar Sail Lookalike”→
Ion thrusters are an amazing spacecraft propulsion technology, providing very high efficiency with relatively little fuel. Yet getting one to produce more thrust than that required to lift a sheet of A4 paper requires a lot of electricity. This is why they have been only used for applications where sustained thrust and extremely low fuel usage are important, such as the attitude management of satellites and other spacecraft. Now researchers in New Zealand have created a prototype magnetoplasmadynamic (MPD) thruster with a superconducting electromagnet that is claimed to reduce the required input power by 99% while generating a three times as strong a magnetic field.
Although MPD thrusters have been researched since the 1970s – much like their electrostatic cousins, Hall-effect thrusters – the power limitations on the average spacecraft have limited mission profiles. Through the use of a high-temperature superconducting electromagnet with an integrated cryocooler, the MPD thruster should be able to generate a very strong field, while only sipping power. Whether this works and is as reliable as hoped will be tested this year when the prototype thruster is installed on the ISS for experiments.
In a Universe ruled by the harsh and unyielding laws of Physics, it’s often tempting to dream of mechanisms which defy these rigid restrictions. Although over the past hundred years we have made astounding progress in uncovering ways to work within these restrictions — including splitting and fusing atoms to liberate immense amounts of energy — there are those who dream of making reality a bit more magical. The concept of asymmetrical electrostatic propulsion is a major player here, with the EmDrive the infamous example. More recently [Dr. Charles Buhler] proposed trying it again, as part of his company Exodus Propulsion Technologies.
This slide from Dr. Buhler’s APEC presentation shows the custom-made vacuum chamber built to test their propellantless Propulsion drive in a simulated space environment. Image Credit: Exodus Propulsion Technologies, Buhler, et al.
The problem with such propellantless space propulsion proposals is that they violate the core what we know about the physical rules, such as the conclusion by Newton that for any action there has to be an opposite reaction. If you induce an electrostatic field or whatever in some kind of device, you’d expect any kind of force (‘thrust’) this creates to act in all directions equally, ergo for thrust to exist, it has to push on something in the other direction. Rocket and ion engines (thrusters) solve this by using propellant that create the reaction mass.
The EmDrive was firmly disproven 2021 by [M. Tajmar] and colleagues in their paper titled High-accuracy thrust measurements of the EMDrive and elimination of false-positive effects as published in CEAS Space Journal, which had the researchers isolate the EmDrive from all possible outside influences. Since the reported thrust was on the level of a merest fraction of a Newton, even the impact from lighting in a room and body heat from the researchers can throw off the results, not to mention the heat developed from a microwave emitter as used in the EmDrive.
Meanwhile True Believers flock to the ‘Alt Propulsion Engineering Conference’ (APEC), as no self-respecting conference or scientific paper will accept such wishful claims. In the case of [Buhler], he claims that their new-and-improved EmDrive shows a force of 10 mN in a ‘stacked system’, yet no credible paper on the experiments can be found other than APEC presentations. Until their prototype is tested the way the EmDrive was tested by [M. Tajmar] et al., it seems fair to assume that the rules of physics as we know them today remain firmly intact.
There are many wonderful places we’d like to visit in the universe, and probably untold numbers more that we haven’t even seen or heard of yet. Unfortunately…they’re all so darn far away. A best-case-scenario trip to Mars takes around six months with present technology, meanwhile, if you want to visit Alpha Centauri it’s a whole four lightyears away!
When it comes to crossing these great distances, conventional chemical rocket technology simply doesn’t cut the mustard. As it turns out though, lasers could hold the key to cutting down travel times in space!
An unfortunate property of science-fiction is that it is, tragically, fiction. Instead of soaring between the stars and countless galaxies out there, we find ourselves hitherto confined to this planet we call Earth. Only a handful of human beings have ever made it as far as the Earth’s solitary moon, and just two of our unmanned probes have made it out of the Earth’s solar system after many decades of travel. It’s enough to make one despair that we’ll never get anywhere near the fantastic future that was seemingly promised to us by science-fiction.
Yet perhaps not all hope is lost. Over the past decades, we have improved our chemical rockets, are experimenting with various types of nuclear rockets, and ion thrusters are a common feature on modern satellites as well as for missions within the solar system. And even if the hype around the EMDrive vanished as quickly as it had appeared, the Alcubierre faster-than-light drive is still a tantalizing possibility after many years of refinements.
Even as physics conspires against our desire for a life among the stars, what do our current chances look like? Let’s have a look at the propulsion methods which we have today, and what we can look forward to with varying degrees of certainty.
