Our post about what it takes to convert your home to solar power probably put you in a green mood, but if you want to start with something smaller, check out this guide on how to add a solar panel to your lawnmower.
You will need a battery-powered lawnmower for this, as well as a 12-volt solar charger with a car lighter jack. This easy hack mainly involves a small amount of work with the wiring; the car lighter jack must be removed from the solar panel so that the wires can be attached to the batteries. Yeah, that’s it. We’d love to see a more elegant solution since the way it is now you have switch the wiring from parallel to series everytime you want to mow.
For a more complete lawnmower hack, check out this remote control lawnmower.
