[sgk] built this tiny ethernet board to be used with the Arduino. It’s based on a WIZnet W5100 chip. The chip handles all of the TCP/IP communication and you talk to it via SPI. It’s compatible with the standard Arduino ethernet library. [sgk] hand soldered these boards including the 80pin LQFP main chip. His next project is to put the AVR and W5100 all on the same board. It sounds like he’ll use components larger than 1005 though.
15 thoughts on “Tiny Arduino Ethernet Board”
Leave a Reply to zachCancel reply
I know it’s not in the hacking spirit, but you could buy an actual module for $15.90 from the chip company. Its not certified Arduino, but who cares. http://www.ewiznet.com/goods_detail.php?goodsIdx=114
@odin84gk that looks pretty promising. 40 bucks for a XPort module always seemed expensive, when I could just use a computer as a proxy. I think I could live with $16, though.
This article inspired me to finally read the datasheet I had lying around for the Wiznet 5100, and I now have some big plans for this chip.
If you’re planning to use the module you might find some of my stuff of use:
http://code.rancidbacon.com/Netduino
–Phil.
@Odin84gk arduino is mentioned because that bit will click into the arduino. Personally I’m surprised I can’t buy a preassembled shield with a w5100 onboard.
hmm whats the max thruoutput I can get with this chip?
That’s very nice work for a hand job. I wish I had that kind of skill with a set of irons.
rasz- their website indicates 50Mbps. that’s bits not bytes.
dan- quality hand jobs require patience and practise. The first few I did, I rushed and it showed but I kept with it and now i’m quite proud of the techniques i use. when the boss needs a good hand job, I’m the one he calls first.
Time for a captcha….
“when the boss needs a good hand job, I’m the one he calls first.” -jimmys
You can’t take that one back. :-D
odin84gk- I don’t get it, can you explain it to me?
http://www.zaslike.com/files/gdyhmc29n75i37owysy.jpg
A lot of people talk about it, i guess it’s great
Any good sites to watch it? I’ve found Inglorious Basterds but looking for a dvd rip if it’s available already?
Thnx in advance
Здравствуйте уважаемые форумчане, недавно искал подруге какой нибудь парфюм, и бороздя в бескрайних просторах интернета набрел на сайт про французский парфюм зашел посмотрел вопервых нашел всю нву касательно того что искал а во вторых просто провел хорошо время , ведь на нем так менго сопуствующих статей. Вобщем если вы как и я что нибудь ищете по данной теме то рекоммендую! Всем удачи и хорошегоо вам серфинга в бескрайних просторах ;)
Hi people! I have heard about site – vk.com. I didn’t use it, but some people who was, say that it’s much better than facebook! Is it true? Does anybody here using VK?
