Impressioning At LockCon
impressioning
[Steffen Wernéry] has published a video of the impressioning contest at LockCon. We learned about key impressioning at this year’s HOPE conference. You start the process by inserting a key blank into the lock. By turning the lock until it stops and then moving the key up and down you create marks on the blank’s face. Take a file to those marks to remove the extra material and then repeat the process. Once the pins are set properly, they’ll stop leaving marks on the blank. It takes a lot of skill to do this right, but you end up with a perfectly functional key. [Barry Wels] managed to win the competition in 5:30 with second place coming in at 6 minutes.
Kill A Watt Teardown
killawatt
Come on, folks. If we keep tearing apart everything that’s handed to us, we’ll never get nice things. SparkFun got their mitts on two Kill A Watts and proceeded to plug them into everything and then dismantled them to see how they work. The Kill A Watt keeps track of how much power is used over time. The largest load they found was their soda machine using 500W (should probably add a motion sensor to that). They plugged a meter on either side of a UPS and found out that it uses 5W just to charge. On the inside of the meter, there isn’t anything too substantial. One unlabeled IC runs the whole show.
WaldFlöte: Midi Controlled Pipe Organ
Members of Dorkbot Edinburgh have done what most of us would do if we had a 19th century pipe organ. They hacked it to be midi controlled. The organ is located above a cafe owned by the university of Edinburgh. Students have been repairing and modifying it to get it back in working order.
The electronics are composed of an Xilinx Spartan-3E Starter Kit as the brains and a Microblaze processor converting midi events for the solenoids.  The cool thing is that none of this required any permanent modification to the organ itself.  It can all be removed to put the organ back in normal playing condition. Check out the video after the break for some classical Van Halen.
Continue reading “WaldFlöte: Midi Controlled Pipe Organ” →
