How many times has this one happened to you? Just coming home from work, you walk in from the garage, settle down, and pick up the newspaper. But wait, did you remember to shut the garage door?
Presenting the open garage door indicator. [xjc2010] chose the simplest circuit possible, using only a switch to turn on and off the setup, an LED acting as the signal, and a transformer/resistor combo to drop the voltage to an acceptable LED friendly 2.8 volts. We don’t like how he strung wire all over his house to place the beacon, and would have preferred something wireless in one way or another, but for under 6 bucks this gets the job done quickly and cheaply. Now if only we could get it to remind us if we turned off the oven while on vacation.
[thanks Craig]
