Chiptune Instrument From NES
[Jarek Lupinski] wanted an instrument that would let him play chiptunes live, without a need for pre-programming a cartridge for playback during a concert. His preferred hardware is an original Nintendo Entertainment System because of its familiar nostalgic sound. After picking up a lot of 5 broken NES units he set out to build a midi-compliant device.
The five NES units he bought had nothing wrong with them other than the 70-pin cartridge connector. He fixed them all, then de-populated the board on one and tried to build out a circuit on a breadboard. After much trial and error, forum searching, and conversations with others who were familiar with the hardware he got the circuit working. He’s posted a schematic and had a board fabricated which takes the transplanted chips and transforms them into an instrument. Check out the test notes being played by an Arduino Mega after the break.
12 thoughts on “Chiptune Instrument From NES
  1. A nice start, but I want to see the finished project back in the NES case. A good goal: MIDI-in right next to the mono audio-out with no other connections required. That’d almost be something you could sell to people…
  2. this is great news
    but i’m wondering why he would use the 2A03
    but then wants to make a cart with it?
    i thought it was going to be it’s own thing
    wonderings: if you can just make something like that that accepts midi
    or something like that where you can change the parameters of the sound
    do you have to use arduinomega
    i want to do this
    i’m glad he’s documenting everything and making it open source
  3. i started with the 2A03 because the original idea was to stuff the entire thing into an electric keyboard to have a synthesizer you can play anywhere. It was only after discovering that 2A03 chips were scarce, and people don’t like tearing open their beloved NES’s that I decided to port it to a cart form factor.
    I only used an Arduino Mega for the proof of concept, the final will probably use an STM32 with multiplexers.
    Have fun! The underlying theory is really complex XD but with a bit of reading at nesdev.com you can figure it out too.
  4. Would it be possible to use an NES Powerglove as the instrument keys for a chip-tune NES? I think that would be perfect. The Hexadecimal buttons and full nes pad, right on your arm. I love the Powerglove, it’s s… oh nevermind.
Leave a Reply to zool Cancel reply
