Multi-system Nintendo Emulator Uses Stock Controllers
The first month of [WoolyDawg5’s] summer break went into building one Nintendo emulator to rule them all. He thinks there’s nothing like playing the games on the original controllers, and we agree with him 100%. Here you can see that the cartridge door on this NES enclosure hides the extra connectors he needs.
With that door closed this looks like a stock console, but only from the front. If you take a look at the back of it you’ll see how he pulled this off. There’s a Zotac motherboard whose I/O panel has been fitted into the back. It’s responsible for emulating games for the NES, SNES, and GameCube consoles — we’re sure it can do more but that covers the controller ports seen here. Each port is wired to a USB controller module. The cables for these modules exit the back of the case and plug into the motherboard’s I/O panel. There is WiFi for the board, and that’s what [WoolyDawg] uses for configuration, tunneling into the OS instead of connecting a keyboard or mouse.
Of course you could just shoehorn all-original console hardware into one package to accomplish something like this.
[Thanks KoldFuzion]
17 thoughts on “Multi-system Nintendo Emulator Uses Stock Controllers
  1. While its cool
    snes and nes (posibly gamecube too) use the same type of port its just in a different physical configuration
    so i just put nes ends on my snes controllers (you do have to swap 2 wires i forget the colors)
    and everything neatly plugs into the regular controller port
    i sent in my emulater in a nes about a year ago but Hack A Day had no interest.
  2. Surely there are internal USB headers on the motherboard? Or at least a small USB HUB to save having all the wires around the back, ruins it i think, so very close to be awesome, just tidy up the back :D
    1. looking through the build pictures he posted, there is one clear shot of the motherboard before he mounted it in the case. It clearly shows a pair of internal USB headers. While it may have been even more cramped – it should have been possible to squeeze a small usb hub hardwired to one of those headers inside.
      Even without going that far – this is an impressive build!
    1. I was going to paint this out as well.
      Those are N64 and the photos on the site show N64 Emulation, not GameCube… GameCube controllers sucked anyway… ;-p
  3. This is one of the latest DSi offer from the renowned Supercard team, which effectively means that it
    is 3DS compatible. Comments: The long awaited sequel to the iconic Deus Ex, a game that received tons of awards and accolades for its “pioneering designs in player choice and multiple narrative paths”.
    Mario is very well-rounded, and Luigi is mostly average, but can jump much
    higher than the other characters. The second game in the series,
    The Lost Levels, was also hidden on the cart if
    you were skilled enough to unlock it. Nintendo 3DS’s Mii Plaza has
    been updated with new touch-controls, four new games and an fresh layout, the company announced this morning.
Leave a Reply to belg4mitCancel reply
