Bluetooth Headset Garage Door Opener Update
bluetooth-headset-garagedoor-opener-update
[Lou Prado] sent in a link to his new video on using a Bluetooth headset as a garage door opener for your Android device. This isn’t a new hack, and we’ve actually seen him pull it off once before back in 2011. But we’re running this as an update for a couple of reasons. First off, we had forgotten about the hack and it’s worth revisiting. Secondly, the headset which he used with the initial hack has gone out of production. He chose a new model, and the assembly video (embedded after the break) which he made is a treasure trove of best practices to use when hacking consumer electronics.
Here’s how the hardware part of the hack goes. He removes the speaker from the headset and solders the base of a transistor in-line with a resistor to the red wire. The emitter connects to the grounded frame of the USB charging cable which is plugged into an outlet next to your garage door opener. The collector of the transistor is then connected to the garage door opener, along with a common ground connection, allowing audio from the headset to trigger the transistor to open the door.
The systems is secure based on Bluetooth pairing, which was done with his phone before starting the hardware hack.
http://www.youtube.com/watch?v=jHOQLcOvhR4
22 thoughts on “Bluetooth Headset Garage Door Opener Update
      1. You can spoof BT MAC addresses, and since those headsets (including this one) always only have 0000 as code that would be all that is needed to hack this system.
        I have different views on what I call secure.
      2. I wouldn’t really trust it in terms of security. There are probably a bunch of people who leave the pair code as 0000 or 1234. Also 10^4 = 10000… not the most difficult thing to brute-force.
        Anyway, because this is just a bluetooth switch, It doesn’t HAVE to be used for the garage door, so that makes it cool in my book.
  1. don’t understand why you have to rip apart a perfectly good bluetooth device when you can get those bluetooth devices on ebay which have an audio jack as output. and theyre like $10.
    1. Reliability and the fact that it can go invisible and needs a physical key to be pressed to be paired and it has voice-feedback messages, which he uses to activate.
      Plus it’s the one he knows and tested.
      But yeah you might find a reasonable cheap one that has the same features.
  2. while i agree with the security sentiment.
    I am pretty sure that if your garage is burglarized, they will be bruteforcing a door or awindow, not your BT
    neat solution in my opinion.
        1. What scenario are you imagining where this hack would be the difference between getting burgled and not getting burgled? Are there burglars in your area roaming around with RF sensing equipment on the off chance someone has a Bluetooth activated door?
          In any case, the problem is that worrying about that stuff is a misallocation of resources. If gaining access to the garage gains you access to the entire house, or grants you access to anything more valuable than a snow shovel and a lawn mower you have much, much bigger problems to deal with before you worry about your choice of wireless door remote protocol.
          1. But if someone can seemingly legitimately get into your garage they can easily close the door and then break down the access door with any tool they like, nobody will be surprised by noise form a garage after all.
            As for who would know, how about the guy who sold the kit and his computer, which can be hacked too.
            Although admittedly the chances are slim someone finds out they are still existing in a real way. And I can tell you from more than one incident that the damn thieves are always looking for opportunity, and there are more of them than you might think and they are quite brazen.
  3. Just remembered my BT Headset beeps when the battery is low or isn’t paired with a device. Remember to check that before you buy for this project or you’ll be wondering why your garage door is opening and closing until you drive up and connect.
    1. This is why he used a specific model, plus it’s connected to the power supply always so the battery never gets low, and if the power fails in the area the opener won’t have power to operate the door.
      It’s still a good reminder though for people trying this on low-cost alternative models.
Leave a Reply to WhatnotCancel reply
