Electric Scooter MK 1 — Tundra Upgrade!
P1140811_600
After discovering his all-terrain snow scooter was terrible on ice — [Dane] decided he needed to do some upgrades.
In case you don’t remember, we first shared [Dane’s] project back in December, where he zipped around city streets covered in snow. The scooter used a big knobby tire and a front ski to slide around on. To make it suitable for ice, he had to redesign it a bit to handle slippery surfaces; he needed to give it skates.
He had originally hoped to find figure skates at a thrift store (where he originally found the classic scooter), but had no luck — so he made his own. Some 1/2″ x 1/4″ steel bar later, a bit of welding, and he had a rather rugged front skate to work with!
After he was content with his upgraded front-end, he started adding studs to the back tire. He’s using plain old 3/8″ self tapping screws, and a whole lot of epoxy to make sure they stay in.
So does it work? Oh yeah.
Continue reading “Electric Scooter MK 1 — Tundra Upgrade!”
WS2812b Ambilight Clone For The Raspi
For how often the Raspberry Pi is used as a media server, and how easy it is to connect a bunch of LEDs to the GPIO pins on the Pi, we’re surprised we haven’t seen something like Hyperion before. It uses the extremely common WS2812b individually controllable RGB LEDs to surround the wall behind your TV with the colors on the edges of the screen.
One of the big features of Hyperion is the huge number of LEDs it’s able to control; a 50 LED strip only eats up about 1.5% of the Pi’s CPU. It does this with a “Mini UART” implemented on the Pi running at 2MHz.
There’s only one additional component needed to run a gigantic strip of RGB LEDs with a Pi – an inverter of some sort made with an HCT-series logic chip. After that, you’ll only need to connect the power and enjoy a blinding display behind your TV or monitor.
Thanks [emuboy] for sending this one in.
3D Printering: Custom RC Camera Mount Takes To The Sky
3DP-Main2
3D Printers are only good for printing trinkets and doodads, right?  Not really. Although, I do print the occasional useless object, most of my prints are used for projects I’m working on or to meet a need that I have. These needs are the project’s design requirements and I’d like to share the process and techniques I use when creating a functional 3D object.
My pal [Toshi] has RC Airplanes and flies often. I have an Action Camera that I never use. Why not combine the two and have some fun? The only thing standing in our way was a method to mount the camera to the airplane. 3D printing makes it easy. If you have a popular vehicle or application, there may be something already available on a 3D model repository like Thingiverse. Our situation was fairly unique I decided to design and print my own mount.
Continue reading “3D Printering: Custom RC Camera Mount Takes To The Sky”
The Mostly 3D Printed Violin
violin
While Thingiverse is filled with Ocarinas, there’s little in the way of printable instruments for more serious musicians. [David Perry] hopes to change this with the F-F-Fiddle, the mostly 3D printed full-size electric violin.
The F-F-Fiddle is an entry for the LulzBot March 3D Printing Challenge to make a functional, 3D printed musical instrument. Already there are a few very, very interesting submissions like this trombone, but [David]’s project is by far the most mechanically complex; unlike the other wind and percussion instruments found in the contest, there are a log of stresses found in a violin, and printing a smooth, curved fingerboard is quite the challenge.
While there are a few non-printed parts, namely the strings, a drill rod used as a truss rod, some awesome looking tuners, and of course the piezo pickups – the majority of this violin, including the bridge, is 3D printed. It’s an amazing piece of work, and after listening to the video (below), sounds pretty good too.
You can grab all the files on Thingiverse and read up on the build at Openfab PDX.
Continue reading “The Mostly 3D Printed Violin”
Shapeoko 2 Mods: Dust Mitigation And Limit Switches
so2-main
Not long ago the Shapeoko 2 came out. In case you missed it, the Shapeoko 2 is the 2nd generation bench-top CNC Router of the namesake. All axes roll on Makerslide and v-wheels. The X and Y axes are belt driven, power is transmitted to the Z axis by lead screw.
As with most products, there will be people who must hack, mod or upgrade their as-received item.  If you are a regular Hackaday reader, you are probably one of those people. And as one of those people, you would expect there have been a few individuals that have not left this machine alone.
Continue reading “Shapeoko 2 Mods: Dust Mitigation And Limit Switches”
Copper Oxide Thermoelectric Generator Can Light An LED
On Hackaday, we usually end up featuring projects using building blocks (components, platforms…) that can be bought on the market. We however don’t show many hacks that rely on basic physics principles like the one shown in the picture above.
In the video embedded below, [nylesteiner] explains that copper oxide can be formed when heating a copper wire using a propane flame. When two oxidized wires are placed in contact with each other, an electrical current is produced when one wire is heated much hotter than the other. The trade-off is that the created thermocouple generates a small voltage but a ‘high’ current. However, when you cascade 16 junctions in series you can generate enough voltage to light up an LED. Even though the complete system isn’t particularly efficient at converting heat into electricity, the overall result is still quite impressive in our opinion. We advise our readers to give a look at [nylesteiner]’s article and blog to discover his interesting adventures.
Continue reading “Copper Oxide Thermoelectric Generator Can Light An LED”
