What do you get when you take a massive number of LEDs and combine them with a shopping cart and a bicycle? An awesome rave-mobile created by [kramerr]. He’s even taking it one step further by making the electronics solar powered.
[Kramerr] controls the LEDs with multiple WS2803 LED drivers. Three PIC18F4550s control the WS2803s over SPI. He devised a neat way of exciting the LEDs from music by using a pair of graphic equalizer display filter chips, MSGEQ7s, to drive the PICs to create patterns. A USB input also allows the PICs to display song titles or other information.
The mechanical design is as impressive as the electronics. The rear half of a bicycle is welded to the frame of the shopping cart with the cart’s handle used for steering. The shopping cart’s rear wheels are replaced by small bicycle wheels.
But [Kramerr] wasn’t done. He built his own solar panel since he couldn’t find one to fit the size requirements. The panel consists of 26 cells connected in series to provide 1A at 13V on a sunny day. A solar charge controller keeps a standard 12v lead acid battery ready to power the tricycle cart.
And there is still more! There is a sound system driven by a Raspberry Pi. The Pi also drives the USB inputs when [Krameer] wants to display song titles or artists instead of the audio patterns.
There are at least four hacks in this project each worthy of applause. [Karmeer] deserves an ovation for doing all of them in one project. If you are looking for less bling and less pedaling may we direct you to this powered, riding shopping cart.
Some rave music and lights via video after the break.
Looks . I want one. Amazing.
sometimes kids prefer the box the gift came in…
screw that!
I WANT A SHOPPING CART!
the lights i can supply …
PS: best shopping cart ever
PPS: just finished reading build-log… WOW just WOW im so impressed, im usually less then amazed when i see other’s lights because i like my set better, but this… i just cant make anything as good, even if i was to mount things to a cart like this guy did (cart=transportHUGEbattery)
PPPS: to all the trolls, … yes, i HAVE made the news with my lights,
but this guy’s “space-dance command-center” as i call it,
tops everything ive ever seen in LED “stuff” ever. EVER
Kramerr eh.. well OK :)
That instructable is quite intensive incidentally, lots of parts used and lots of description and lots of templates and support files provided. You have to respect the effort that went into all of it. 35 steps (pages) it says on top.
