In somewhat of a departure from their normal fare of heavy metal mods, [Make It Extreme] is working on a battery pack for an e-bike that has some interesting design features.
The guts of the pack are pretty much what you’d expect – recovered 18650 lithium-ion cells. They don’t go into details, but we assume the 52 cells were tested and any duds rejected. The arrangement is 13S4P, and the cells are held in place with laser-cut acrylic frames. Rather than spot weld the terminals, [Make It Extreme] used a series of strategically positioned slots to make contacts from folded bits of nickel strip. Solid contact is maintained by cap screws passing between the upper and lower contact frames. A forest of wires connects each cell to one of four BMS boards, and the whole thing is wrapped in a snappy acrylic frame. The build and a simple test are in the video below.
While we like the simplicity of a weld-less design, we wonder how the pack will stand up to vibration with just friction holding the cells in contact. Given their previous electric transportation builds, like this off-road hoverbike, we expect the pack will be put to the test soon, and in extreme fashion.
Large high current, high voltage battery banks are soldered or spot welded for a reason
you really don’t want dicky connections on such a thing … at several dozen amps threw a few milliohms of contact resistance can create several watts of heat that can easily snowball as the heat speeds up oxidation
not saying its wholly unsafe, but i am saying i wont be powering my house off temporary contact li-ions any time soon :P
So you’re saying the problem will fix itself as it spot-welds the high resistance connections.
no it wont, the hotter the contact gets the more it will corrode making the connection even hotter, the resistance will go up as it heats and can easily get red hot, pumping all that heat in to the battery causing even more problems with resistance
im going to agree with lou and say in any high power constant load application like motor driving … its probably totally unsafe
high power pulse applications like an ECig or low power applications like a sensor, flashlight, your 5W diy projects are probably okay with press fit contacts like a socket
but i mean your soldering so much already … just solder your batteries in your DIY projects
takes no time at all with a little bit of flux and a chisel tip and while your at it get protected batteries
a good rule of thumb is when dealing with li-ion batteries, dont cut corners
“a good rule of thumb is when dealing with li-ion batteries, dont cut corners”
So never solder directly to batteries! Buy batteries with solder tabs or build/get a spot welder.
no, 18650 cells are soldered in industry all the time, there are literally jigs for it sold professionally and defined by samsung and LG
as long as you dont hold the iron on it for an hour its more than alright
Never solder anything if you can’t solder properly with the right equipment. I solder reclaimed 18650s all the time and have never had one get hot. But then I have 40yrs practice and the right equipment.
If the tabs are tinned steel then it would just solder itself :D
Yep, and this follows last months article on a similar ill-conceived bike-battery connector arrangement.
Can you please explain why would such kind method of battery connection loosing power? If comparing the same method of glass fuse holder, which has on one side spring connector, and on another site flat-solid? And, we know the fuses have big role in electricity world, which need to do job very accurate, and reliable.
I’ll go one further and say it is totally unsafe. For the love of God man please spot weld those connections. There’s a reason why people do it.
Probably. But I wonder if the people who go around saying this have any clue on what that reason might be…
a good rule of thumb for li-ion batteries is to never cut corners … if you dont know why someone does something and you dont want to look it up … just do it too
plus a DIY spot welder is a very fun project and a good way to upcycle your old microwave and frayed jumper cables
All the high amp power everyone uses daily is connected without solder. Take a look in your electric panel where you reside….rotary phase converters…AC units….the high amp alternator and battery in your vehicle (No solder). Copper is the way to go for connecting high output 18650 batteries. Soldering or spot welding 20 mil + copper isn’t an option for most.. Time for most of you to start thinking outside the box.
In fact, I do have a clue. This fire-trap relies on the spring-action of the metal maintaining a very-low ohm connection. Just a few hundredths of an Ohm, from oxide, dirt, frog-snot or whatever, and now you have a few (to many) Watt heater. In a confined space. Pushed together by Plexiglas /plastic . Which gets soft when hot. Which “pushes” the connections together less. Creating more resistance. Creating more heat. In a confined space. Making the plastic soft.. Getting the joint hotter…. Anyone want to make a prediction here? Any fortune-tellers about? I will take a shot. IT ends in fire. a metal fire. A lithium metal fire. Word of caution, don’t try to put it out with water.
Fortunately it’s no Li-metal fire. There is no metallic lithium in a lithium ion battery. But there is still enough flammable stuff around: Organic electrolytes: flammable; carbon electrodes: flammable; Acrylic holder: flammable. And abunch of stored energy when the pack is charged.
But it’s still worse then “relies on the spring-action of the metal maintaining a very-low ohm connection”: there are no metal springs, the “elasticity” of the PMMA is supposed to press on the contact. But when it gets warm it gets more plastic. Polymers are often called “plastics” or “thermoplastic” for a good reason.
It’s actually even better…a charged litihum ion call has the (very) porous carbon negative electrode loaded with metallic lithium, giving waaaay more surface then if it was just a chunk of metal…
If you use enough water you will definitely put it out, but personally I’d recommend trying dry sand ;-)
That is one low density battery. Especially for an eBike.
Well…. – https://en.oxforddictionaries.com/definition/hover
“Remain at or near a particular level.”
“Remain poised uncertainly in one place or between two states.”
So technically speaking, they do hover.
This was meant to be a reply to Greenaum’s comment above.
Colin Furze installed a pulsejet engine into a street bicycle, making “the most dangerous unsafe bike ever”. But I think the e-bike with the unwielded battery pack from this entry, is even worse.
Heh, at least the pulse jet is supposed to go on fire.
Like the design and think it’s great but is there not a big problem there with it?.
It being all plastic won’t it get hot and start causing problems? Plus it’s not very sealed up well but then I know you made it open for air to get around it. But all that plastic stacked together to hold the batteries won’t it get hot when you run something that takes a load of power will it not warm things up inside that plastic sandwich you made? All am I getting this all wrong?. It look nice what you done just not sure on the safety side of it?.
I am quite sure on the safety side of this: terrible. batteries connected series and parallel with intermittent connections.
It may not be hovering, but it’s pining for it.
Back to point. Decades ago I figured out thst 7-11 met tbe criteria for “several.” The median is 9. Several dozen is 9×12=108. I^2R=Power(Loss.) 108×108= 11,664. 11,664 x 0.001 Ohms is 11.664 watts. Forget a few milliohms. 1 causes 11W loss per junction. Recall how warm a 7W Christmas tree bulb got? Several milliohms must be an exaggeration. Hopefully in ALL junction-cases. It would otherwise be untenable.
This is very unsafe. Contacts degrade. There is no elastic element pushing them. Temperature changes. And acrylic and vibration? No thanks.
There are so many ways to easily spot weld: 12V acid battery, super caps, microwave oven transformer…
No soldering but laser cutting the case – that’s surely a hint for the casual maker :-)
Bully…
Jolly good chaps ( except the hater wishing leathal outcome )
Good show I say.
Post test results when the battery pack is put through its paces— extreme lloads and is a thermal graph or FLIR camera too much?
Nice pack but i wouldn’t draw more than a few amps through a spring connection. I have a couple 3 and 4s spring pack holders, vibration and heat tend to disconnect the cells, in 1p config it just shuts down but may overload a pararelle pack if it were 2p.
umm did they just completly weld shut that enclousure? i saw him applying the glue to the top and the bottom. Interesting design process, make a component and asume its perfect before integrating it into the larger project. Although it could be the ultimate troll because i find my self curious about the next part of the larger project.
Recovered cells is kind of a recipe for disaster in a pack this big – they have been suspect in several electric longboard fires. The serious battery builders are starting to follow Tesla and have cell-level fuses (24 ga wire I think) to a buss bar in their packs.
Also acrylic seems a little cracky for something that’s going to be in a vehicle. Maybe HDPE? It’s soft, strong and forgiving.
Otherwise good build!
It looks ehh and ended up heavy and unsafe with its mismatched cells and unreliable connections. But hey at least he engraved the side!
Seriously this content doesn’t belong here as anything but a warning or example of what not to do.
If that’s make it extreme, what to call my 14S8P pack from recycled cells? My pack will also have the ability to parallel several DeWalt 60V lithium packs to extend range.
It’s “make it extreme”, half his projects are half thought out so why should this be any different?
Why not use large RC packs from a source like HobbyKing? It feels like a much better option than these heavy battery builds. They’re cheaper per kWh, higher discharge rate, lighter, less labor, smaller volume, last longer due to less internal resistance, etc. I had an 18650 pack, but the weakest links would always need to be replaced and would prematurely wear out the good ones. I started to buy better batteries, but the cost was significantly more.
I’ve been using two 7S 12Ah packs on my ebike for two years now and it works great. Protection circuitry even monitors battery temps.
P.S. maybe add article tag ‘ebike’ along with e-bike’.
Junctions between dissimilar metals or alloys are prone to galvanic corrosion. The welding process mixes the metals to a degree forming a zone of alloy between the two which helps buffer the galvanic effect. Contacts essentially do ‘spot weld’ but do so at the asperities only.
Blah blah blah, it’s complicated! :D
will the 4 90deg bends per tab change the resistance?
Really you got a plasma cnc and ya worried about welds? Shit if we all had plasma CNC’s we wouldn’t be building our own battery packs just buy the MOFO! Connect three 18v drill batteries together on a removable rack without modifying the OEM batteries and done, 15 mins tops super quick charging as ya can just swap out the cells.
I have used compression and welding on a 72 volt, 75 ah battery with a 100 amp continuous bms (21700 lion). Energy flow, longevity, and heat dissipation were all better when batteries were connected with compression rather then welding. My method is a bit different. I use .8mm pure copper that I divet for the positive anode. I then apply an n52 neodymium magnet to the top of the cells 15p x 20s. I then shrink wrap it and keep it in a water proof battery box. I have absolutely tortured this battery on my fat bike at an average of about 5000 watts for over a thousand miles of wet, muddy, and rocky terrain of the Pacific Northwest. Not a single problem. I took the battery out cut the wrap off of it and there is absolutely no corrosion, discoloration, dislocation, battery looks just like when I installed it. So don’t believe the welders, test compression out, it is better!!
Mike, could you provide more details on this? I am extremely interested, as I am about to embark on building a 72v, 40ah, 20s, 10p battery pack for my vintage scooter. I have a 4000 watt hub motor for it. There is so much info out there about spot welding vs soldering, etc. This method with magnets and copper sounds interesting.
Thanks in advance for any help.
I second that. I live in the PNW and am interested in not having to toss out an entire pack because a couple of cells go bad…
Do battery packs plug into the system with a spring/friction style plug?
First, in my opinion, the idea of this solution without welding the connections is sustainability. The batteries were taken out from use battery packs with partly defective cells. Even the saved ones will not last as long as new one. So the circles of maintenance will be more often to tear off the welding and ripping the stripes. I just did this on a large battery pack. It is stressful, and you can hurt yourself due to the sharp metal stripes. It is not a matter to afford to invest into a spot welder for anybody to design and laser cut this great holder. Second, I think due to the high pressure of the traversing screws, there is a good chance for reliably remaining good connection to the batteries, without getting hot due to high resistance. There might be ways to improve it, but basically I like the idea. Thumbs up!
These kind of contacts can not carry high loads. Corrosion is the smallest problem you will have.
