MIT Makes Washable LED Fabric
Let’s face it, one of the challenges of wearable electronics is that people are filthy. Anything you wear is going to get dirty. If it touches you, it is going to get sweat and oil and who knows what else? And on the other side it’s going to get spills and dirt and all sorts of things we don’t want to think about on it. For regular clothes, that’s not a problem, you just pop them in the washer, but you can’t say the same for wearable electronics. Now researchers at MIT have embedded diodes like LEDs and photodetectors, into a soft fabric that is washable.
Traditionally, fibers start as a larger preform that is drawn into the fiber while heated. The researchers added tiny diodes and very tiny copper wires to the preform. As the preform is drawn, the fiber’s polymer keeps the solid materials connected and in the center. The polymer protects the electronics from water and the team was able to successfully launder fabric made with these fibers ten times.
The waterproofing isn’t just good for the laundry. The fibers even work underwater as the team demonstrated by transmitting music through water in a fish tank.
We often see research like this and have to admit that practical use of it will be many years away, if ever. However, according to reports, commercial products using these fibers will start appearing in 2019.
16 thoughts on “MIT Makes Washable LED Fabric
  1. “We often see research like this and have to admit that practical use of it will be many years away, if ever. However, according to reports, commercial products using these fibers will start appearing in 2019.”
    Include some sensors and your clothes can tell you when the washer has gotten everything clean. One blink, dirty. Two blinks, clean.
      1. I never dive in shark populated places, because there are none where I live :)
        I’m much more interested in cave diving, where seeing our buddies in every (sometime muddy) condition means : Avoiding a deadly accident.
Leave a Reply to IzzyCancel reply
