Listen To A Song Made From Custom Nintendo LABO Waveform Cards
[Hunter Irving] has been busy with the Nintendo LABO’s piano for the Nintendo Switch. In particular he’s been very busy creating his own custom waveform cards, which greatly expands the capabilities of the hackable cardboard contraption. If this sounds familiar, it’s because we covered his original method of creating 3D printed waveform cards that are compatible with the piano, but he’s taken his work further since then. Not only has he created new and more complex cards by sampling instruments from Super Nintendo games, he’s even experimented with cards based on vowel sounds in an effort to see just how far things can go. By layering the right vowel sounds just so, he was able to make the (barely identifiable) phrases I-LIKE-YOU, YOU-LIKE-ME, and LET’S-A-GO.
Those three phrases make up the (vaguely recognizable) lyrics of a song he composed using his custom waveform cards for the Nintendo LABO’s piano, appropriately titled I Like You. The song is at the 6:26 mark in the video embedded below, but the whole video is worth a watch to catch up on [Hunter]’s work. The song is also hosted on soundcloud.
2 thoughts on “Listen To A Song Made From Custom Nintendo LABO Waveform Cards
  1. Supernintendo sounfonts are actually a very precise fit for this: the SNES sound chip was great at processing multi-channel PCM audio, but had only a tiny memory so individual repeating waves would get played instead in most cases,
Leave a Reply to Steven ClarkCancel reply
