Bringing Back The Fidget Toy Craze With The Magic Microcontroller Cube
[Rickysisodia] had a few dead ATmega128 chips laying around that he didn’t want to just throw away, so he decided to turn them into his own light-up fidget toy. The toy is in the form of a six-sided die so small that you can hang it on a keychain. He soldered an ATmega128 on each side of the cube and added a few dot circles to give his toy the look of a functional dice. We were pretty amazed by his impressive level of dexterity. Soldering those 0.8 mm-pitch leads together seems pretty tedious if you ask us.
Then he wired a simple, battery-powered tilt switch LED circuit on perfboard that he was able to sneakily place inside the cube. He used a mercury switch, which, as you may figure, uses a small amount of mercury to short two metal contacts inside the switch, completing the circuit and lighting the LED. We would suggest going with the non-mercury variety of tilt switches just to avoid any possible contamination. You know us, anything to mitigate unnecessary disasters is kind of a good route. But anyway, the die lights up a different color LED based on the orientation of the cube and it even blinks.
This is a pretty cool hack for wowing your friends at your next PCB art meet-up. We’ll probably put this in the electronics art category, so it doesn’t get lumped in with those other ever-beloved fidget toys.
17 thoughts on “Bringing Back The Fidget Toy Craze With The Magic Microcontroller Cube
  1. I’m not really seeing the anti-stress properties. What do you DO with it? D&D? Monopoly? Let it sit in your pocket and change the battery every day? Perhaps some battery charging contacts would be a VERY good upgrade to do right away. It’s certainly pretty, but I’m not sure marketing has figured out their niche yet.
Leave a Reply to NormCancel reply
