Schlieren On A Stick
Schlieren imaging is a technique for viewing the density of transparent fluids using a camera and some clever optical setups. Density of a fluid like air might change based on the composition of the air itself with various gasses, or it may vary as a result of a sound or pressure wave. It might sound like you would need a complicated and/or expensive setup in order to view such things, but with a few common things you can have your own Schlieren setup as [elad] demonstrates.
His setup relies on a cell phone, attached to a selfie stick, with a spherical mirror at the other end. The selfie stick makes adjusting the distance from the camera to the mirror easy, as a specific distance from the camera is required as a function of focal length. For cell phone cameras, it’s best to find this distance through experimentation using a small LED as the point source. Once it’s calibrated and working, a circular field of view is displayed on the phone which allows the viewer to see any change in density in front of the mirror.
The only downside of this build that [elad] notes is that the selfie stick isn’t stiff enough to prevent the image from shaking around a little bit, but all things considered this is an excellent project that shows a neat and useful trick in the photography/instrumentation world that could be useful for a lot of other projects. We’ve only seen Schlieren imaging once before and it used a slightly different method of viewing the changing densities.
10 thoughts on “Schlieren On A Stick
  1. “Schlieren setup”… It’s funny how you use that German word. Schlieren is not the name of the person who invented it. It is just the word for visible streaks inside a fluid (or inside glass, but that’s also a fluid).
    1. Schlieren is actually a town in Germany. It is funny how after the popularity of “Dark” there are so many German experts popping up on the internet.
      1. I didn’t know Switzerland was in Germany. It is funny how after the popularity of written language there are so many experts poping up in the world.
      2. Schlieren imaging is _not_ named after a town, Daniel ist quite right. And we were there all along, it’s just that we speak your language too…
  2. I love it. I’m going to attempt a schlieren photography setup using a big fresnel lens instead of a parabolic mirror. (I think it’ll work.)
    1. I would love to see this.
      The biggest issue with schlieren setups is the size of the mirror. If you want to image a bowl of soup but your mirror is small, then you are out of luck. Big spherical/parabolic mirrors are expensive.
      Your idea would be awesome, because big fresnel lenses are cheap and east to get.
      Good luck, and make sure you share the results!
Leave a Reply to DECancel reply
