JavaScript App Uses Advanced Math To Make PCBs Easier To Etch
We all remember the litany from various math classes we’ve taken, where frustration at a failure to understand a difficult concept bubbles over into the classic, “When am I ever going to need to know this in real life?” But as we all know, even the most esoteric mathematical concepts have applications in the real world, and failure to master them can come back to haunt you.
Take Voronoi diagrams, for example. While we don’t recall being exposed to these in any math class, it turns out that they can be quite useful in a seemingly unrelated area: converting PCB designs into easy-to-etch tessellated patterns. Voronoi diagrams are in effect a plane divided into different regions, or “cells”, each centered on a “seed” object. Each cell is the set of points that are closer to a particular seed than they are to any other seed. For PCBs the seeds can be represented by the traces; dividing the plane up into cells around those traces results in a tessellated pattern that’s easily etched.
To make this useful to PCB creators, [Craig Iannello] came up with a JavaScript application that takes an image of a PCB, tessellates the traces, and spits out G-code suitable for a laser engraver. A blank PCB covered with a layer of spray paint, the tessellated pattern is engraved into the paint, and the board is etched and drilled in the usual fashion. [Craig]’s program makes allowances for adding specific features to the board, like odd-shaped pads or traces that need specific routing.
This isn’t the first time we’ve seen Voronoi diagrams employed for PCB design, but the method looks so easy that we’d love to give it a try. It even looks as though it might work for CNC milling of boards too.
28 thoughts on “JavaScript App Uses Advanced Math To Make PCBs Easier To Etch
  1. Does anyone know of a similar application that works on a vector format PCB rather than on raster images? I am routing my PCBs on a CNC machine so my workflow is Gerber -> isolation -> NC code. This works fine but traces and pads have too much detail. If I could reduce the complexity of the isolation vector format using Voronoi diagrams it would significantly cut down the routing time.
    1. Yes, I built a tool that does precisely that:
      https://github.com/abetusk/gbr2ngc
      It doesn’t do Voronoi regions but rather does polygon boolean operations (via the library clipperlib) and polygon offsetting, if desired, to account for the endmill radius.
      gbr2ngc is fully RS-274X compliant though you should always be looking out for bugs.
  2. Nice. It looks like it has a side effect of minimizing the tool path length at the same time. Handy.
    But good luck drilling those holes on center. The drill is going to want to walk into that gutter.
    A good update would be to put a center starting hole in the middle of the intended through-hole.
    1. One should drill at least pilot holes using CNC as well. For doing this, regular PCB milling applications are just fine. I typically drill 0.75mm and 1.00mm by CNC, this cover like 90% Then enlarge the bigger ones manually. Drilling like 250 holes manually is a chore.
    1. But they’re really not once you add shipping charge (min $15+).
      Then a week+ waiting time.
      For each iteration.
      You can easily blow $100 and a month of delay using china boards, vs a day or two diy.
  3. I would have liked my profs to explain math with interesting application examples instead of (mostly) showing how cool (wir hey think) they are dealing with super abstract ideas…
  4. This is for casual use and low requirement non-critical circuits.
    If your application requires you to control the width and shape of PCB traces, then this is not what you want. e.g. Analog grounding, PCB traces for current measurement, capacitance sensing, high speed circuits, controlled impedance, RF application where the traces are used as antenna, inductor etc.
  5. Just doing “flood fill” (while leaving boundaries intact) everywhere that’s empty would accomplish the goal of reducing the amount of etching required. The traces would be left alone, so their lengths and thicknesses would not change.
      1. pcb2gcode –voronoi –preserve-thermal-reliefs
        Even without thermal reliefs a 1oz copper PCB is a breeze with a 25W iron, but 2oz needs a 60W to 100W iron.
        The 3 second rule has always been true, in that if you can’t finish the joint with a nice fillet in 3 seconds you are using the wrong equipment. As cooking the joint with a small iron often causes a lot of damage to the PCB/parts.
Leave a Reply to AndrewCancel reply
