Lego Microscope Aims To Discover Future Scientists
When it comes to inspiring a lifelong appreciation of science, few experiences are as powerful as that first glimpse of the world swimming in a drop of pond water as seen through a decent microscope. But sadly, access to a microscope is hardly universal, denying that life-changing view of the world to far too many people.
There have been plenty of attempts to fix this problem before, but we’re intrigued to see Legos used to build a usable microscope, primarily for STEM outreach. It’s the subject of a scholarly paper (preprint) by [Bart E. Vos], [Emil Betz Blesa], and [Timo Betz]. The build almost exclusively uses Lego parts — pretty common ones at that — and there’s a complete list of the parts needed, which can either be sourced from online suppliers, who will kit up the parts for you, or by digging through the old Lego bin. Even the illuminator is a stock part, although you’ll likely want to replace the orange LED buried within with a white one. The only major non-Lego parts are the lenses, which can either be sourced online or, for the high-power objective, pulled from an old iPhone camera. The really slick part is the build instructions (PDF), which are formatted exactly like the manual from any Lego kit, making the build process easily accessible to anyone who has built Lego before.
As for results, they’re really not bad. Images of typical samples, like salt crystal, red onion cells, and water fleas are remarkably clear and detailed. It might no be a lab-grade Lego microscope, but it looks like it’s more than up to its intended use.
Thanks for the heads up on this, [Jef].
7 thoughts on “Lego Microscope Aims To Discover Future Scientists
  1. You can get sharper results from cheap lenses by limiting the light spectrum used to illuminate the object being observed. Human eyes are very sensitive to green light, so using a green LED can give nice sharp images with lots of contrast.
    1. that gets rid of the color abberation. it may be a good idea to check what color gives the best results. not all lenses have the same sharpness for a given color.
    1. Unless you are talking about the pasta sauce which is spelled with two g’s and an apostrophe, i.e. Leggo’s.
Leave a Reply to SaabmanCancel reply
