Hackaday Links: May 8, 2022
Hackaday Links Column Banner
Russia’s loose cannon of a space boss is sending mixed messages about the future of the International Space Station. Among the conflicting statements from Director-General Dmitry Rogozin, the Roscosmos version of Eric Cartman, is that “the decision has been made” to pull out of the ISS over international sanctions on Russia thanks to its war on Ukraine. But exactly when would this happen? Good question. Rogozin said the agency would honor its commitment to give a year’s notice before pulling out, which based on the current 2024 end-of-mission projections, means we might hear something definitive sometime next year. Then again, Rogozin also said last week that Roscosmos would be testing a one-orbit rendezvous technique with the ISS in 2023 or 2024; it currently takes a Soyuz about four orbits to catch up to the ISS. So which is it? Your guess is as good as anyones at this point.
At what point does falsifying test data on your products stop being a “pattern of malfeasance” and become just the company culture? Apparently, something other than the 40 years that Mitsubishi Electric has allegedly been doctoring test results on some of their transformers. The company has confessed to the testing issue, and also to “improper design” of the transformers, going back to the 1980s and covering about 40% of the roughly 8,400 transformers it made and shipped worldwide. The tests that were falsified were to see if the transformers could hold up thermally and withstand overvoltage conditions. The good news is, unless you’re a power systems engineer, these aren’t transformers you’d use in any of your designs — they’re multi-ton, multi-story beasts that run the grid. The bad news is, they’re the kind of transformers used to run the grid, so nobody’s stuff will work if one of these fails. There’s no indication whether any of the sketchy units have failed, but the company is “considering” contacting owners and making any repairs that are necessary.
For your viewing pleasure, you might want to catch the upcoming documentary series called “A League of Extraordinary Makers.” The five-part series seeks to explain the maker movement to the world, and features quite a few of the luminaries of our culture, including Anouk Wipprecht, Bunnie Huang, Jimmy DiResta, and the gang at Makers Asylum in Mumbai, which we assume would include Anool Mahidharia. It looks like the series will focus on the real-world impact of hacking, like the oxygen concentrators hacked up by Makers Asylum for COVID-19 response, and the influence the movement has had on the wider culture. Judging by the trailer below, it looks pretty interesting. Seems like it’ll be released on YouTube as well as other channels this weekend, so check it out.
But, if you’re looking for something to watch that doesn’t require as much commitment, you might want to check out this look at the crawler-transporter that NASA uses to move rockets to the launch pad. We’ve all probably seen these massive beasts before, moving at a snail’s pace along a gravel path with a couple of billion dollars worth of rocket stacked up and teetering precariously on top. What’s really cool is that these things are about as old as the Space Race itself, and still going strong. We suppose it’s easier to make a vehicle last almost 60 years when you only ever drive it at half a normal walking speed.
And finally, if you’re wondering what your outdoor cat gets up to when you’re not around — actually, strike that; it’s usually pretty obvious what they’ve been up to by the “presents” they bring home to you. But if you’re curious about the impact your murder floof is having on the local ecosystem, this Norwegian study of the “catscape” should be right up your alley. They GPS-tagged 92 outdoor cats — which they dryly but hilariously describe as “non-feral and food-subsidized” — and created maps of both the ranges of individual animals, plus a “population-level utilization distribution,” which we think is a euphemism for “kill zone.” Surprisingly, the population studied spent almost 80% of their time within 50 meters of home, which makes sense — after all, they know where those food subsidies are coming from.
13 thoughts on “Hackaday Links: May 8, 2022
  1. Interesting. One: I’ve seen those big crawlers before, also the big pads that roost on top of them before. And two: I saw that one about those Scandinavians and their talent for watching cats watch them. I happen to know what six ones I knew very well did. They spent their time working on their places to sleep in.
  2. Considering the launch facility was in Florida (no freezing) you think it would have been easier to move rockets on a barge and canal than a crawler?
    1. I’d figure that with a canal and barge, you’d have it doing an Ever Given if the wind was wrong on a large structure. Then there’s probably hydrodynamic issues if you’re tryna keep the width down and precision up, but you’ve gotta displace megatons of water to load it and move it. Then there’s stability issues, be like standing up in a canoe.
      1. Plus of course they’d probably have seen Gerry Anderson’s productions and figured the crawler was the cool way to do it…
    2. They considered that for the Vehicle Assembly Building and transport to the launchpad actually, but it was ultimately rejected because of fears that in a structure as massive as the VAB having the floor made of water would wreak havoc on the humidity levels inside the building.
  3. Weren’t those crawler treads in a scene in the original Star Wars movie for the land crawler?
    When the sun farts on us those power transformers may be the first to pop.
  4. I would have thought the appropriate Cartman quote for the behaviour of the head of Roscosmos was “YOU WILL RESPECT MY AUTHORITAH!”
  5. It only took 40 years but we finally know how they managed to beat GE on the price of transformers and win those contracts.
    Guess you get what you pay for, maybe there should be fines for the anti-competitive practices
    /s
Leave a Reply to Anool MahidhariaCancel reply
