A Non-Destructive Digital Back For A Classic Leica
As digital photography has become so good, perhaps just too good, at capturing near-perfect pictures, some photographers have ventured back into the world of film. There they have found the imperfections requiring technical skill to cope with that they desire, but they’ve also come face-to-face with the very high cost and sometimes sketchy availability of film stocks. From this has come the so-called post-digital movement which marries analog cameras and lenses with digital sensors, and of this a particularly nice example comes from [
Perhaps the best thing about this conversion, and something which should propagate forward into other builds, is the way it does not hack or modify the original camera beyond the replacement of the already-removable back. A vintage Leica is a pricey item, so it would be a foolhardy hacker who would proceed to gut it for a digital conversion. Instead he’s mounted everything that makes a digital camera, the sensor, Pi Zero, and screen board, behind the camera body. The Pi shutter trigger comes from the Leica’s flash terminal, meaning that there’s plenty of time for it to take a photo while the shutter is open.
He’s admirably preserved the usage and properties of the Leica, and his photographs as can be seen in the video below the break bear testament to what is possible with the camera. He still has to work with the tiny sensor size though, meaning that all photographs are at a much higher zoom level than on the original. We would love to see a camera conversion like this one that incorporates appropriate lenses to bring the picture to focus on this small sensor.
We won’t own a Leica any time soon, but we like this conversion. It’s by far the most sympathetic, but it’s not the first rangefinder conversion we’ve seen.
Continue reading “A Non-Destructive Digital Back For A Classic Leica” →
3D Design With Text-Based AI
Generative AI is the new thing right now, proving to be a useful tool both for professional programmers, writers of high school essays and all kinds of other applications in between. It’s also been shown to be effective in generating images, as the DALL-E program has demonstrated with its impressive image-creating abilities. It should surprise no one as this type of AI continues to make in-roads into other areas, this time with a program from OpenAI called Shap-E which can render 3D images.
Like most of OpenAI’s offerings, this takes plain language as its input and can generate relatively simple 3D models with this text. The examples given by OpenAI include some bizarre models using text prompts such as a chair shaped like an avocado or an airplane that looks like a banana. It can generate textured meshes and neural radiance fields, both of which have various advantages when it comes to available computing power, training methods, and other considerations. The 3D models that it is able to generate have a Super Nintendo-style feel to them but we can only expect this technology to grow exponentially like other AI has been doing lately.
For those wondering about the name, it’s apparently a play on the 2D rendering program DALL-E which is itself a combination of the names of the famous robot WALL-E and the famous artist Salvador Dali. The Shap-E program is available for anyone to use from this GitHub page. Even though this code comes from OpenAI themselves, plenty are speculating that the AI revolution to come will largely come from open-source sources rather than OpenAI or Google, something for which the future is somewhat hazy.
Your Childhood Inventions Brought To Life
If you are the kind of person who reads Hackaday, you probably spent time in school doodling little design day dreams. [Allen Pan] gets it, and he’s taken it upon himself to make some of those daydreams into reality. You can see how it worked out — or didn’t — in the video below.
The video starts out with suction cup boots for walking on the ceiling, a laser sword made with a mirror, a plunger gun, and lawnmower boots. Some of these were more successful than others.
Continue reading “Your Childhood Inventions Brought To Life” →
The Peak Of Vacuum Tube Radio Design
One of the more popular trends in the ham radio community right now is operating away from the shack. Parks on the Air (POTA) is an excellent way to take a mobile radio off-grid and operate in the beauty of nature, but for those who want to take their rig to more extreme locations there’s another operating award program called Summits on the Air (SOTA) that requires the radio operator to set up a station on a mountaintop instead. This often requires lightweight, low-power radios to keep weight down for the hike, and [Dan] aka [AI6XG] has created a radio from scratch to do just that.
[Dan] is also a vacuum tube and CW (continuous wave/Morse code) operator on top of his interest in summiting various mountains, so this build incorporates all of his interests. Most vacuum tubes take a lot of energy to operate, but he dug up a circuit from 1967 that uses a single tube which can operate from a 12 volt battery instead of needing mains power, thanks to some help from a more modern switch-mode power supply (SMPS). The SMPS took a bit of research, though, in order to find one that wouldn’t interfere with the radio’s operation. That plus a few other modern tweaks like a QCX interface and a switch to toggle between receive to transmit easily allows this radio to be quite versatile when operating while maintaining its portability and durability when summiting.
For those looking to replicate a tube-based radio like this one, [Dan] has made all of the schematics available on his GitHub page. The only other limitation to keep in mind with a build like this is that it tends to only work on a very narrow range of frequencies without adding further complexity to the design, in this case within the CW portion of the 40-meter band. But that’s not really a bad thing as most radios with these design principles tend to work this way. For some other examples, take a look at these antique QRP radios for operating using an absolute minimum of power.
Hackaday Prize 2023: Finger Tracking Via Muscle Sensors
Whether you want to build a computer interface device, or control a prosthetic hand, having some idea of a user’s finger movements can be useful. The OpenMuscle finger tracking sensor can offer the data you need, and it’s a device you can readily build in your own workshop.
The device consists of a wrist cuff that mounts twelve pressure sensors, arranged radially about the forearm. The pressure sensors are a custom design, using magnets, hall effect senors, and springs to detect the motion of the muscles in the vicinity of the wrist.
We first looked at this project last year, and since then, it’s advanced in leaps and bounds. The basic data from the pressure sensors now feeds into a trained machine learning model, which then predicts the user’s actual finger movements. The long-term goal is to create a device that can control prosthetic hands based on muscle contractions in the forearm. Ideally, this would be super-intuitive to use, requiring a minimum of practice and training for the end user.
It’s great to see machine learning combined with innovative mechanical design to serve a real need. We can’t wait to see where the OpenMuscle project goes next.
Continue reading “Hackaday Prize 2023: Finger Tracking Via Muscle Sensors” →
What Is A Schumann Resonance And Why Am I Being Offered A 7.83Hz Oscillator?
Something that probably unites many Hackaday readers is an idle pursuit of browsing AliExpress for new pieces of tech. Perhaps it’s something akin to social media doomscrolling without the induced anger, and it’s certainly entertaining to see some of the weird and wonderful products that can be had for a few dollars and a couple of weeks wait. Every now and then something pops up that deserves a second look, and it’s one of those that has caught my attention today. Why am I being offered planar PCB coils with some electronics, described as “Schumann resonators”? What on earth is Schumann resonance, anyway? Continue reading “What Is A Schumann Resonance And Why Am I Being Offered A 7.83Hz Oscillator?” →
Hackaday Podcast 218: Open Source AI, The Rescue Of Salyut 7, The Homework Machine
This week, Editor-in-Chief Elliot Williams and Kristina Panos have much in the way of Hackaday news — the Op Amp Challenge is about halfway over, and there are roughly three weeks left in the Assistive Tech challenge of the 2023 Hackaday Prize. Show us what you’ve got on the analog front, and then see what you can do to help people with disabilities to live better lives!
Kristina is still striking out on What’s That Sound, which this week honestly sounded much more horrendous and mechanical than the thing it actually is. Then it’s on to the hacks, beginning with the we-told-you-so that even Google believes that open source AI will out-compete both Google’s own AI and the questionably-named OpenAI.
From there we take a look at a light-up breadboard, listen to some magnetite music, and look inside a pair of smart sunglasses. Finally, we talk cars, beginning with the bleeding edge of driver-less. Then we go back in time to discuss in-vehicle record players of the late 1950s.
Check out the links below if you want to follow along, and as always, tell us what you think about this episode in  the comments!
Download and savor at your leisure.
Continue reading “Hackaday Podcast 218: Open Source AI, The Rescue Of Salyut 7, The Homework Machine” →
