3D Printing LEGO-like Blocks
LEGO are perhaps the perfect children’s toy, at least until you step on the errant brick while walking around the house. Available in all kinds of sets with varying themes and characters, they encourage building and creativity in kids like no other. Those with 3D printers might have considered creating their own specialty blocks, but the manufacturing of real LEGO blocks involves steel molds with extremely tight tolerances far outside the realm of most 3D printers. To print blocks capable of interconnecting in a similar way involves taking advantage of the characteristics of 3D printers and their materials instead, as [CNC Kitchen] demonstrates with these PrintABloks.
The PrintABlok was the idea of [Joe Larson] aka [3D Printing Professor] and is built around a one-unit base block, which has holes on all of its sides, paired with small connecting pieces which are placed in the holes to connect the various blocks to one another. Using your CAD software of choice (although they were originally built using Blender), the base block can be lengthened or widened for printing various different types of blocks, and the diamond-shaped hole can even be added to various prints that aren’t blocks at all. This means that a wide variety of parts can be made, all designed to interlock with the bricks or various other shapes. [Joe] even created an array of themed sets like robots, castles, and dinosaurs and although he sells these more complex models, he released his base set and interconnection mechanism for free and is available for anyone to use.
Another perk of the PrintABlok system is that they are scalable, mitigating safety risks for smaller children that might try to swallow some of the smaller parts. It’s an excellent way to put the 3D printer to work if there are any children around in the house. But this isn’t the only LEGO-inspired build we’ve ever seen, and they aren’t always going to be used to make children’s toys. [Ivan] recently used similar 3D-printed interlocking bricks more in the style of LEGO Technic to attempt to build a human-rideable go-kart.
8 thoughts on “3D Printing LEGO-like Blocks
  1. I’ve seen recently a yt video of mr. Larson explaining how it evolved to the current form.
    Also I suspect that HaD is sneaking on my web hystory list because again I found here videos/articles that i saw/read within one or two weeks earlier.
  2. Very cool. However, I would point out that one of the features of round pegs is that it helps maintain rigidity which is important with larger structures. Build something tall and you’ll quickly see the structure “slouch” under it’s own weight.
      1. Yes, because lego blocks are routinely connected together using free angles… /s
        You can actually customize these parts arbitrarily since you’re the one printing them, which eliminates the issue altogether.
  3. I quite like this idea.
    Using standard blocks and extending the collection with parts you can print yourself.
    Also, because there is a hole through the center, you can put some screws or all-thread through it to make stronger connections in places where it’s needed. I’m not sure about the exact size of these, would there be enough room to print in some holes near all corners for some all-thread?
Leave a Reply to paulvdhCancel reply
