Do you ever find yourself eating walnuts and think, this would make a great enclosure for something like a Bluetooth speaker? That seems to be exactly what happened to [Penguin DIY].
In the mesmerizing video after the break, you’ll see [Penguin DIY] do what seems to be impossible. They start with a tiny 5 V power bank module which is still not small enough to fit, so they remove all the components and dead-bug them back together.
This is really just the beginning. There of course has to be a female USB of some type, so [Penguin DIY] Dremels out the perfect little slot for it.
They did manage to stack and fit a MH-MH18 Bluetooth audio module and an HXJ8002 mini audio amplifier module in the walnut, but of course, it took a lot of fiddly wiring to extend the LEDs and wire them up.
Then in the other half of the shell went the 4Ω 2 W mini speaker. [Penguin DIY] of course drilled a ton of little holes in the shell for the sound to come through. Also on this side are three tiny switches for play/pause and previous and next track, and the latter two can be long pressed to control the volume. Definitely check this out after the break.
Do the notifications of your Bluetooth speaker annoy you? There’s a hack for that.
Thanks for the tip, [Hyperific]!
I bet the sound is nuts!!!
I’m speechless ! This is pure art ! Congrats !!!!
Why did [Penguin DIY] make a walnut speaker?
FOR THE CRACK!!! :-D
Sorry, I’ll get my coat…
This is nuts! (in a good way…)
“Do you ever find yourself eating walnuts and think, this would make a great enclosure for something like a Bluetooth speaker?”
No but I’ve seen them used to hide condoms. It was sold under the name “Crack a nut”.
….Why would anyone need to HIDE condoms?
@kristina, you’ve got a typo, the bluetooth module is MH-M18.
Now get a squash and pumpkin install a 12 inch subwoofer or larger depending how good your farmer is, and Bluetooth, sprinkle a few of the walnuts using esp32 and ad hoc wifi to daisy chain to the main receiver, cuz Bluetooth can’t connect to multiple devices at once
Give Dolby, thx, a run for they 💵
Now you have true surround home stereo
…..Yep, that’s it in a nutshell…..
thanks a lot, this made me fail No Nut November :(
Question: “Do you ever find yourself eating walnuts and think, this would make a great enclosure for something..?”
Answer: Ahhh, no. Never would have thought of it. :) Clever though.
It might be too good of a “dead drop” enclosure for spies.
Well, we’ve already had apple and acorn computing devices…
Don’t forget Apricot!
I could swear I remember one of the regular columnists in mid-1970s Popular Electronics magazine doing a “what new products will we see in The Year 2000” once. The two items I remember: “blue LEDs” and “hi-fi speakers the size of a walnut”. Better late than never!
Is it possible to connect an apple for better Battery live? :)
Olaf
Instead of buttons, accelerometer would be more stealth, and also don’t have to worry about the buttons wearing out.
