Mini DDR Cabinet Gets Maximum Upgrade
Those shrunken-down arcade cabinets are a nifty idea, but they sure do suck in practice. At least, the Dance Dance Revolution game is full of empty promises. With the $25 cabinet, all you get are three songs that come out of a crappy little speaker, and a not-great display to match.
[BigRig Creates] endeavored to make it better, however, and managed to cram a Raspberry Pi 4 in the cabinet without disturbing the stock components too much. They did have to trim every extraneous piece of plastic from the inside of the cabinet and trim the I/O pins down, but it fit.
What didn’t fit are the fans that [BigRig Creates] needed once it was clear that it was necessary to overclock the Pi. As [BigRig Creates] points out, a custom PCB would have saved some room. And perhaps time. And definitely some wires.
Unfortunately, it wasn’t that simple on the software side. (It never is, is it?) Even getting the screen to work was no picnic. But in the end, it worked, and even survived a bunch of gamers testing it out at LTX. Check it out after the break.
Got an old PS2 DDR controller? You could make it play Simon instead.
Thanks for the tip, [Gerald]!
2 thoughts on “Mini DDR Cabinet Gets Maximum Upgrade
Leave a Reply to YoDrTentaclesCancel reply
