Digital Audio Workstation In A Box
Although it’s still possible to grab a couple of friends, guitars, and a set of drums and start making analog music like it’s 1992 and there are vacant garages everywhere yearning for the sounds of power chords, the music scene almost demands the use of a computer now. There are a lot of benefits, largely that it dramatically lowers the barrier to entry since it greatly reduces the need for expensive analog instruments. It’s possible to get by with an impressively small computer and only a handful of other components too, as [BAussems] demonstrates with this tiny digital audio workstation (DAW).
The DAW is housed inside a small wooden box and is centered around a Behringer JT-4000 which does most of the heavy lifting in this project. It’s a synthesizer designed to be as small as possible, but [BAussems] has a few other things to add to this build to round out its musical capabilities. A digital reverb effects pedal was disassembled to reduce size and added to the DAW beneath the synthesizer. At its most basic level this DAW can be used with nothing but these components and a pair of headphones, but it’s also possible to add a smartphone to act as a sequencer and a stereo as well.
For a portable on-the-go rig, this digital audio workstation checks a lot of the boxes needed including MIDI and integration with a computer. It’s excellent inspiration for anyone else who needs a setup like this but doesn’t have access, space, or funds for a more traditional laptop- or desktop-centered version. For some other small on-the-go musical instruments we recently saw a MIDI-enabled keyboard not much larger than a credit card.
4 thoughts on “Digital Audio Workstation In A Box
  1. A friend of mine bought a DAW in a box for his studio around 30 years ago. The box was a six feet tall 19″ rack. IIRC The system cost about UKP90k and stored about 80 minutes of multitrack audio. How times change,
  2. If you only want to track, Caustic on G-Play will do it all. It’s a rack of 9 keyboards, mixing, and tracking for all. Everything lags if played live though. I mostly deal with live music so I have no need for it though it’s free to try. It does midi OTG. Not a hack itself but things can go further. Like phone jambox blaster with sub and stereo speakers, the Hammond with “Leslie” effect is worth it alone. This will weigh far less than a real B3 and Leslie.
Leave a Reply to FlotsamCancel reply
