Pico Logic Analyzer Gets New Version
[Happy Little Diodes] built a Pi Pico logic analyzer designed by [El Dr. Gusman] using the original design. But he recently had a chance to test the newest version of the design, which is a big upgrade. You can see his take on the new design in the video below.
The original design could sample 24 channels at 100 MHz and required two different PCBs. The new version uses a single board and can operate up to 400 MHz. There’s also a provision for chaining multiple boards together to get more channels. You can set the level shifters to use 5 V, 3.3 V, or an external voltage. Since [Happy] is working on a ZX Spectrum, the 5 V conversion is a necessity.
The code is on GitHub, although it warns you that version six — the one seen in the video — isn’t stable, so you might have to wait to make one on your own. The software looks impressive and there may be some effort to integrate with Sigrok.
If you missed our coverage of the earlier version, you can still catch up. Dead set on Sigrok support? [Pico-Coder] can help you out.
26 thoughts on “Pico Logic Analyzer Gets New Version
  1. I am travelling so I cannot watch the video, but how does is the sampling rate reach 400MS/s? Is the creators overclocking the 133MHz ARM cores? I know RP2040 is dual core, so I wonder if they can/are “staggering” the running of the code on the two cores to get better sampling rate?
    Very cool project, always loved the concept of using cheap dev boards as logic analyser. Back when i was in univ I wrote my own logic analyzer for an AVR to record the IR signals to an air conditioner. Fun times.
    1. I’m more curious how he’s getting the data off the rp2040. When I messed with using one as a logic analyzer the number one limit was the USB 1.0 being too slow to offload the data in real time. So you’d rapidly fill the RAM and could only sample for short periods.
      1. If you are looking for a real-time continuous stream, I recently released hsdaoh-rp2350, which streams out the data via HDMI to a $5 MS2130-based USB 3.0 capture dongle.
        I also added a 16 bit @ 32 MHz logic analyzer example: https://github.com/steve-m/hsdaoh-rp2350
        This of course can be adapted for up to 8 bit @ 75 MHz, 4 bit @ 150 MHz and so on.
        For testing I adapted libsigrok to use libhsdaoh as a data source (https://github.com/steve-m/hsdaoh), but I haven’t cleaned up the driver code yet. Works quite well for me.
        1. Better do 16bit 40 MHz ADC with 9226. But I’m not sure you can obtain 80 Mbyte/sec sustainable transfer through Rpi Pico 2350. And there a lot of unclear things in your project (i.e. how you ovetclock 2350 but not only)
          1. As you might have seen, my external_adc example does exactly that, sample at 40 MHz with an AD9226. The AD9226 is a 12 bit ADC however, so 60 MB/s is enough.
            There even is a PCB already that also adds an audio ADC so it can be used for vhsdecode: https://github.com/Sev5000/Pico2_12bitADC_PCMAudio
            What is unclear to you? For the ADC example the sys_clk is overclocked to 320 MHz, this worked fine with the five Pico2 I have here.
            And the “how”, by a simple function call: https://github.com/steve-m/hsdaoh-rp2350/blob/master/apps/external_adc/external_adc.c#L131
      1. That’s still not the explanation. He overvolts and overclocks the RP2350 from 150 MHz to 400 MHz @ 1.30V.
        Wait, what did the article say again? – “The code […] isn’t stable […]”
        Oh, it is the code for sure.
    2. You are correct that is overclocked. He says 400 mhz in the video. Not sure if the pico 2 has a different base frequency but you may be right about staggering the cores.
      1. yeah, but only among themselves. but if you look at the rp2040 board, some signals move to the outermost edge of the pcb board, running for 2cm while others are basically next to the pins, not more than 5mm. i do not see that difference corrected on the main board.
    1. I just had 5 board made at PCBWay. Had all the components placed, except the Raspberry PI Pico 2’s. I wanted to source those from a source that I trust because of the GPIO issue. In total, the cost of one board was about 18 euro.
      If I had purchased the components and hand-soldered everything myself, the cost would likely have been around 13 euro per board.
      Capabilities are great for my needs. And I would add that up to now I have been using a vintage Nicolet 800 logic analyser (vintage as in: it’s from 1982 or so, and is a CP/M machine of the size and weight of a Compaq Portable :D), and under ‘capability’ understand that it’s possible to have it on my desk together with my project. Which is hardly possible with the Nicolet. :D
      Also the Nicolet does 20msps, I think. And even without any special mode, this Pico Logic Analizer still does 200msps.
      The Nicolet has 32 channels, the Pico has 24. But I can cascade them, and with 5 boards, I have 120 channels…? :+)
      I think this device is great. For sure it cannot be compared to a modern logic analyzer. But if we take both capabilities (10x faster) and size (1,000x smaller) into account, then this board is at least 10,000x better than my Nicolet. ;) Taking cost into account, well, the Nicolet cost me nothing, but I think it’s purchase price was some $15,000. So that’s another 1,000x better. Which makes this board about a million times better than my Nicolet. ;)
      The software can use a few usability improvements, but is already quite usable.
  2. Sigrok is great, but in last 3 years they seem to be rather reluctant to merge contributions lately… That made me rather salty… I wish i had enough will to fork it.
    1. 400 MHz is the sample frequency of the synchronous clocked inputs, not the bandwith. The TXU0104 is asynchronous. He overclocks the RP2350 to 400 MHz which is out of specs (nominal 150 MHz) and overvolts it to 1.30 V
      In my eyes a logic analyzer without continous streaming capability is useless nowadays. I have been using Saleae 16 Pro for 7 years and do not want to switch to anything else.
  3. A lot of comments here about the overclocking and pushing the pico beyond its spec. I just want to note how impressive it is that we can do this in the first place. I think as engineers (more specifically as hobbyist engineers) we learn about the limits of a device and how we’re supposed to use it. Those are written down on paper in a lot of ways they become sacrosanct.
    But then we learn that electronics – just like everything else in our flexible, material world – is malleable, to a degree. And we push. And we get wild stuff like this. It’s awesome. And I’m glad that there’s a way to share it.
Leave a Reply to Andrea CampanellaCancel reply
