Keebin’ With Kristina: The One With The Grasshopper Typewriter
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Do you consider your keyboard to be a fragile thing? Meet the glass keyboard by [BranchNo9329], which even has a glass PCB. At least, I think the whole thing is glass.
The back side of an all-glass keyboard. Yeah.
Image via [BranchNo9329] via reddit
There are so frustratingly few details that this might as well have been a centerfold, but I thought you all should see it just the same. What we do have are several pictures and a couple of really short videos, so dive in.
I can tell you that [BranchNo2939] chose a glass substrate mainly due to curiosity about its durability compared with FR4. And that the copper circuitry was applied with physical vapor deposition (PVD) technology.
Apparently one of [BranchNo2939]’s friends is researching the bonding of copper on to glass panels, so they thought they’d give a keyboard a go. Right now the thing is incomplete — apparently there’s going to be RGB. Because of course there’s going to be RGB.
erkbd Can Be yrkbd, Too
Erik + Keyboard = erkbd, and now [EarflapsOpen]’s wide split is open-source and now has a fully documented build guide on GitHub by special request.
The left half of erkbd, a freshly-documented split keyboard.
Image by [EarflapsOpen] via reddit
Inspired mostly by the Corne and the Void Ergo S layout, this is a 44-key, hand-wired number that runs on a pair of Waveshare RP2040 Zeros programmed with QMK.
I really like the inclusion of OLEDs and rotary encoders, although I feel I would inadvertently turn them by accident. Maybe not. At the very least, they appear to be taller than the keys and might get in the way.
[EarflapsOpen] addresses this a bit at the bottom of the reddit thread, stating that they are not in the way when typing. But since they are kind of far from the home row, you have to move your entire hand to use them. Currently, [EarflapsOpen] uses them for scrolling, adjusting volume, video scrubbing, and so on.
The Centerfold: Battle Axes
A cozy corner with guitars on the wall, more guitars in a rack, and, oh yeah -- a desk with a keyboard and stuff. But yeah, it's mostly guitars.
Image by [delusionalreddit] via reddit
So perhaps [delusionalreddit]’s setup is a bit of a departure from the regular centerfold material, but that’s okay. Just look at all those guitars! Yours truly is down to just six or so, and really ought to have them situated similarly around the laboratory. Maybe someday.
So there isn’t much detail here, especially about the peripherals, and I apologize for that. Please see the next paragraph. Almost no one sends me centerfolds! You know your keeb is sexy; now get it out there.
Do you rock a sweet set of peripherals on a screamin’ desk pad? Send me a picture along with your handle and all the gory details, and you could be featured here!
Historical Clackers: the Williams
When the people demand some new advancement in technology, the early response by manufacturers can sometimes be less than appealing, visually speaking.
The Williams typewriter, "a stunning piece of industrial art that salutes the design mantra of form following function".
A Williams No. 1 model. Image by The Antikey Chop
This is not the case with the stunning Williams line of  typewriters, which were developed in response to heavy demand for visible typewriters — machines that let the typist see what was being typed without having to stop and do something first. Of course, you could only see a few lines at a time, and just by peering over the tippy-top of the machine, but this was revolutionary.
Form follows function in these lovely machines, which don’t seem to waste an inch of space on frivolity. To create visibility, the Williams typewriters had the platen situated in the center, between two sets of type bars that struck from the front and rear, kicking like grasshopper legs. The paper is first secured along the top and curled downward into the basket.
Don’t quite understand? Don’t blame you. Check out this short video, which demonstrates how to insert paper and type on a Williams Academy model.
Isn’t that cool? The earliest Williams models like the No. 1 pictured above became available in 1891. The keyboard was curved slightly, and the body featured Victorian-inspired filigree. Beginning in 1895, the No. 1 was manufactured with a straight keyboard. The No. 2 came out in 1897 and were nearly identical to the straight-keyboarded No. 1s, but they got an upgrade in the form of typebar alignment. No. 2s were also called Academy like the one in the video, or Englewood.
Inventor John Williams was quite the character and inventor, and was known to rub elbows with Alexander Graham Bell and Emile Berliner. He patented all kinds of things, from cigar cutters to one of the first helicopters in 1912. Unfortunately, the Williams Typewriter Company was fairly short-lived, as they were in litigation for patent infringement pretty much the whole time, until 1909. They were acquired by Jerome Burgess Secor, who would go on to produce a completely different typewriter. Stay tuned!
Finally, Another Use for All Those Melty Beads
So [humanplayer2] was having some fun last Saturday while his daughter played with those melty beads. After some trial and error, it seems we have a new viable switch plate material!
Some of those melty beads fused into a small keyboard switch plate.
Image by [humanplayer2] via reddit
The trial and error was, of course, about finding out what inner bead configuration would result in the snuggest fit. As it turns out, a plain old open square holds them the best, followed by hand-cut-away corners, then full interiors.
For what it’s worth, [humanplayer2] was using Hama beads specifically, which is why the holes are almost all completely melted shut.
Keep in mind that not all melty beads are created equally, so your mileage may vary depending on what you’ve got. But it probably shouldn’t matter too-too much in this case, unless you use the ones that are supposed to be really terrible.
Be sure to check out the custom Hama bead game pad he made for her so she can play Paw Patrol in style.
Got a hot tip that has like, anything to do with keyboards? Help me out by sending in a link or two. Don’t want all the Hackaday scribes to see it? Feel free to email me directly.
10 thoughts on “Keebin’ With Kristina: The One With The Grasshopper Typewriter
  1. “Because of course there’s going to be RGB”
    The whole thing is see-through. If anything deserves an RGB treatment, this keyboard surely does.
    1. You could just get an LCD of the appropriate size and aspect ratio and slap it on the bottom.
      That way you’d get millions of lights instead of just a hundred or so.
      1. fluxkeyboard.com
        I’m fascinated by the idea, but it’s way too expensive for me.
        Perhaps an LCD/OLED display under the all-glass keyboard would be cheaper, if lacking the feature of displaying shortcut descriptions.
  2. I’m looking for a compact keyboard for a projet of mine.
    What is the “best” you could find that is 24cm x 10cm ?
    It should be non-mechanical keyboard.
    It could be autonomous or taken from a laptop.
    24×10 should be the visible size from top left key to bottom right key (and for pcb too). Size of border or palmrest does not matter.
Leave a Reply to frenchoneCancel reply
