DIY Penicillin
We don’t often consider using do-it-yourself projects as a hedge against the apocalypse. But [The Thought Emporium] thinks we should know how to make penicillin just in case. We aren’t so sure, but we do think it is a cool science experiment, and you can learn how to replicate it in the video below.
If you want to skip the history lesson, you need to fast-forward to about the six-minute mark. According to the video, we are surrounded by mold that can create anti-bacterial compounds. However, in this case, he starts with a special strain of mold made to produce lots of antibiotics.
You may not have all the gear he uses, including a bioreactor to generate liters of mold. Even with a lot of mold, the yield of penicillin is relatively low. Since Purina doesn’t make mold chow, you’ll have to create your own food for the mold colony.
All the work he did wound up producing 125 milligrams of drug. Obviously, if you are going to save the post-apocalyptic world, you are going to need to scale that process up.
If you are the sole survivor, maybe your AI companion can help out.
16 thoughts on “DIY Penicillin
  1. Would it?
    Its just mold.
    … i say that ignoring the fact that mushrooms and weed are illegal in a lot of places despite growing readily even without intervention
        1. Haha fartichokes… ain’t that the gospel truth. I think the cure is to tie up a diabetic so they only eat those and stay away from the sugary cocktails and donuts and eventually achieve a normal metabolism again. Obviously only works with the vastly most common form of diabetes, not the congenital ones… but in the heckin’ epic SHTF TEOTWAWKI apocalypse, I suspect that form of diabetes would very quickly become rare no matter what you did
  2. Why would it be illegal?
    Selling it, or administering it to someone would definitely be illegal. But making it?
    And in specific circumstances, such as giving it to someone in an emergency to save their life, I don’t think the legality would matter. Such as in New Orleans right after Katrina, when emergency services were spotty.
    1. Sigh, seems we have reached the point where doing anything helpful requires permission from the government(s)… And having a lawyer on hand is probably and excellent idea too.
Leave a Reply to DCECancel reply
