Adorable Robot Steals The Show
An ongoing refrain with modern movies is “Why is all of this CG?”– sometimes, it seems like practical effects are simultaneously a dying art, while at the same time modern technology lets them rise to new hights. [Davis Dewitt] proves that second statement with his RC movie star “robot” for an upcoming feature film.
The video takes us through the design process, including what it’s like to work with studio concept artists. As for the robot, it’s controlled by an Arduino Nano, lots of servos, and a COTS airplane R/C controller, all powered by li-po batteries. This is inside an artfully weathered and painted 3D printed body. Apparently weathering is important to make the character look like a well-loved ‘good guy’. (Shiny is evil, who knew?) Hats off to [Davis] for replicating that weathering for an identical ‘stunt double’.
Check out the video below for all the deets, or you can watch to see if “The Lightning Code” is coming to a theater near you. If you’re into films, this isn’t the first hack [Davis] has made for the silver screen. If you prefer “real” hacks to props, his Soviet-Era Nixie clock would look great on any desk. Thanks to [Davis] for letting us know about this project via the tips line.
Continue reading “Adorable Robot Steals The Show” →
DIY Penicillin
We don’t often consider using do-it-yourself projects as a hedge against the apocalypse. But [The Thought Emporium] thinks we should know how to make penicillin just in case. We aren’t so sure, but we do think it is a cool science experiment, and you can learn how to replicate it in the video below.
If you want to skip the history lesson, you need to fast-forward to about the six-minute mark. According to the video, we are surrounded by mold that can create anti-bacterial compounds. However, in this case, he starts with a special strain of mold made to produce lots of antibiotics.
Continue reading “DIY Penicillin” →
Five Oddest Op Amp Applications
You think of op amps as amplifiers because, no kidding, it is right in the name. But just like some people say, “you could do that with a 555,” [Doctor Volt] might say, “you can do that with an op amp.” In a recent video, you can see below, he looks at simulations and breadboards for five applications that aren’t traditional amplifiers.
Of course, you can split hairs. A comparator is sort of an amplifier with some very specific parameters, but it isn’t an amplifier in the classic sense.
Continue reading “Five Oddest Op Amp Applications” →
A New, Smarter Universal Remote
The remote for [Dillan Stock]’s TV broke, so he built a remote. Not just as a replacement but as something new. For some of us, there was a glorious time in the early 2000s when a smart remote was needed and there were options you could buy off the shelf. Just one handy button next to the screen had a macro programmed that would turn on the receiver, DVD player, and TV, and then configure it with the right inputs. However, the march of technological convenience has continued and nowadays soundbars turn on just in time and the TV auto switches the input. Many devices are (for better or worse) connected to WiFi, allowing all sorts of automation.
[Dillan] was lucky enough that his devices were connected to his home assistant setup. So this remote is an ESP32 running ESPHome. These automations could be triggered by your phone or via voice assistant. What is more interesting is watching [Dillan] go through the design process. Deciding what buttons there should be, where they should be placed, and how the case would snap together takes real effort. The design uses all through-hole components except for the ESP32 which is a module.
This isn’t the first thing [Dillan] has made with an ESP32, as he previously revamped a non-standard smart lamp with the versatile dev board. The 3d printable files for the remote are free available. Video after the break.
Continue reading “A New, Smarter Universal Remote” →
Building A DIY Chicken Incubator
If you want to keep eggs warm to hatch, you’ll need an incubator. You could buy one off the shelf, but they’re not so complex — just a nicely-controlled warm box you could easily whip up yourself. As it turns out, that’s precisely what [RCLifeOn] did.
The incubator is built out of wooden panels screwed together to make a simple box. The frame of the front door is also wood, but it features 3D printed hinges and handles, because that’s the easiest way to make hardware when you’re a printing wizard like [RCLifeOn].
The box is fitted with controls for humidity and temperature to ensure the best possible conditions for hatching chicken eggs inside. As you might have guessed, a heated bed from a 3D printer was used to control the temperature inside. As for humidity, a sensor tracks the conditions in the box, and triggers an ultrasonic mister to increase the level as necessary. There’s also a little motion introduced via a moving platform run by a motor and some step-down gearing, which apparently aids in the hatching process.
[RCLifeOn] calls it “a machine that creates life,” and that honestly sounds about fair. We’ve seen similar projects along these lines before, too.
Continue reading “Building A DIY Chicken Incubator” →
A black and white slide with the Supercon 8 logo in the top left, the text, "Nanik Adnani" and "A Hacker's Guide to Analog Design in a Digital World" is in the bottom left. To the right is a circularly cropped image of An image of a college student in glasses and a cap sitting with a black camera in his lap.
Supercon 2024: A Hacker’s Guide To Analog Design In A Digital World
We often think of analog computing as a relic of the past, room-sized monstrosities filled with vacuum tubes doing their best to calculate Monte Carlo simulations or orbital velocities. Analog isn’t as dead as it might seem though, and analog mix signal design engineer [Nanik Adnani] gave us a crash course on analog circuits at Supercon 2024.
Continue reading “Supercon 2024: A Hacker’s Guide To Analog Design In A Digital World” →
AI Brings Play-by-Play Commentary To Pong
While most of us won’t ever play Wimbledon, we can play Pong. But it isn’t the same without the thrill of the sportscaster’s commentary during the game. Thanks to [Parth Parikh] and an LLM, you can now watch Pong matches with commentary during the game. You can see the very cool result in the video below — the game itself starts around the 2:50 mark. Sadly, you don’t get to play. It seems like it wouldn’t be that hard to wire yourself in with a little programming.
The game features multiple AI players and two announcers. There are 15 years of tournaments, including four majors, for a total of 60 events. In the 16th year, the two top players face off in the World Championship Final.
There are several interesting techniques here. For one, each action is logged as an event that generates metrics and is prioritized. If an important game event occurs, commentary pauses to announce that event and then picks back up where it left off.
We really want to see a one- or two-player human version of this. Please tell us if you take on that challenge. Even if you don’t write it, maybe the AI can write it for you.
Continue reading “AI Brings Play-by-Play Commentary To Pong” →
