Hardware Built For Executing Python (Not Pythons)
Lots of microcontrollers will accept Python these days, with CircuitPython and MicroPython becoming ever more popular in recent years. However, there’s now a new player in town. Enter PyXL, a project to run Python directly in hardware for maximum speed.
What’s the deal with PyXL? “It’s actual Python executed in silicon,” notes the project site. “A custom toolchain compiles a .py file into CPython ByteCode, translates it to a custom assembly, and produces a binary that runs on a pipelined processor built from scratch.” Currently, there isn’t a hard silicon version of PyXL — no surprise given what it costs to make a chip from scratch. For now, it exists as logic running on a Zynq-7000 FPGA on a Arty-Z7-20 devboard. There’s an ARM CPU helping out with setup and memory tasks for now, but the Python code is executed entirely in dedicated hardware.
The headline feature of PyXL is speed. A comparison video demonstrates this with a measurement of GPIO latency. In this test, the PyXL runs at 100 MHz, achieving a round-trip latency of 480 nanoseconds. This is compared to MicroPython running on a PyBoard at 168 MHz, which achieves a much slower 15,000 nanoseconds by comparison. The project site claims PyXL can be 30x faster than MicroPython based on this result, or 50x faster when normalized for the clock speed differences.
Python has never been the most real-time of languages, but efforts like this attempt to push it this way. The aim is that it may finally be possible to write performance-critical code in Python from the outset. We’ve taken a look at Python in the embedded world before, too, albeit in very different contexts.
42 thoughts on “Hardware Built For Executing Python (Not Pythons)
  1. It’s not executing or running any Python. This is someone’s clever custom ISA and there is no python bytecode anymore once the actual program executes. The source language just happens to be python, by the end it is something entirely else for the custom processor which just looks like an FPGA that is fed data by an ARM device.
    Whilst this is smart and intelligent, the promise what it does is misleading a little, probably not intentional. Given the cruft of several chips optimizing something into something entirely new, the speed gains seem rather unsurprising. I am sure some assembly genius can just take an MCU at a certain MHz speed and even laugh about my C code.
    1. Yeah exactly my thoughts. This can be achieved by writing a compiler which would turn python in instructions for whatever architecture it must run on. Its the same as writing C or C++. It still compiles to instructions in the end
      Going by the title of the post I assumed they had built a custom processor which executed Python in hardware, like ARM Jazelle or those old Forth chips. Although again, that’s not too different from writing C but they did have special hardware which actually ran java bytecode in hardware, so its different too
    2. We’ll have to see what makes the hardware part so special in this. I don’t really care about a “Python processor” much like we also don’t have a “C++ processor” or “Java processor”. The latter has been tried and failed.
      But I would give this a fair chance versus the Java attempt, because the way Java/C#/etc. runs on modern systems makes more sense (e.g. JIT compilers which can always optimize for the host ISA). Doing the Python > bytecode > C > machinecode step statically makes sense, but I do wonder what magic sauce is in that bytecode > C > machinecode part, and perhaps more importantly, how fast that would have executed on that 168MHz ARM chip instead. I bet its not going to be 14.7us.
      1. Java processors aren’t considered a failure, at least not by the numbers. They are embedded in the chips found in essentially every payment card issued in the last decade, with billions of them deployed around the globe.
      2. I think I checked the board and it was 250 USD in the OP. So if that won’t execute code fast after optimizing it multiple times, I’d be feeling tricked ;)
        I fully see the hacker who did this is clearly intelligent, but it’s not really a cheap way.
    3. Yeah, that’s what I was thinking.
      Why not execute the bytecode directly?
      That would have been closer than this.
      But that’s still a lot of work, just not what I expected reading the headlines.
    1. Python is also compiled — typically to CPython bytecode.
      PyXL takes that bytecode and translates it into a custom instruction set that’s executed in hardware.
      So while there’s a compilation step, it doesn’t turn Python into a static language like C — PyXL preserves dynamic typing and stack semantics, but runs them far more efficiently.
    2. I write C and C++, but if I could write python and compile it would be much faster to write initially.
      Thats part of the reason I’m using tinygo for a current project. Compiled, a GC, and a decent amount of python like syntax
  2. Nice work, I would love to have spare braincells (and time) to get into FPGA. Seems like a fun project. ARM did once have instructions to accelerate the JVM. One thought, would not a compiler for python do a better job? I don’t do python so no idea how good the compliers for it are. I can’t see why a good compiler could not make it run as good as C code????
  3. A classic example of trying to use the wrong tool for the job. Perhaps the likes of CircuitPython and MicroPython are fine for simple projects where performance is not a concern and provides an easy path into microcontrollers for people who already know some python. There come a point however where you have to learn something new to achieve your goals.
    Python seems to be following a similar path to BASIC, it was the language of choice for beginners to learn programming and some very good software was developed using it, then we had things like the BASIC Stamp that enabled people to use BASIC on a microcontroller, but eventually, if you wanted to progress to building more complex projects, you had to move on from BASIC.
    I have no problem with Python, it is a perfectly good language that I use myself for many things, but it just isn’t a good fit for microcontrollers, learn something new instead of trying to force your preferred language to do things it isn’t intended for.
    1. I beg to differ. Having micropython on a microcontroller presents some advantages:
      – when developing you can use pye (python editor) on the controller itself and edit files directly. No compiler and flashing needed. When the code is working and ready, it can be incorporated into micropython source, then available after flashing
      – performance-critical parts can be rewritten in C and wrapped with Python. then you have the best of both worlds
      For rapid prototyping, it´s a damn efficient workflow.
      1. In my experience prototyping in a different language usually ends up taking mure development time.
        I don’t understand what is peoples objection to C on a small microcontroller. It’s an easy language to learn and most problems people run into are through general lack of discipline. Moreover, at low level many things are a lot easier – for instance switching between a string and array of bytes which in C are one and the same thing
    2. I have to beg to differ. Not just a learning language or ‘have to move on’. It is a perfectly good language for some microcontrollers (like RP2040 and RP2350) for most things. I’ve yet had to drop down to C (and I know this language very well) to improve performance for something I am doing. There is a point where performance is ‘good enough’ now. To read a temperature, to trip a relay, to read open/close status, etc. We are not back in the day where you had to get the last bit of speed and memory use out of the code. With PIO and multi-core you even have more options. Obviously don’t use Python where it won’t fit (use C/Assemby or other favorite compiled language), but don’t be afraid to use Python more and more as the new controllers get more powerful. It is a win for ease of use. That’s of course in my humble opinion.
      1. “We are not back in the day where you had to get the last bit of speed and memory use out of the code. ”
        Micro$oft effect: If it’s bloated and runs poor, you(user) need MORE POWER(to make up for our poor coding)
        I am old enuff to remember what could be done(very well) on a C64 or 8086.
        Quantity not quality is now the rule.
        1. “Quantity not quality is now the rule.”
          Just like what has happened to Amateur(ham) Radio over the last 20++ years.
          -and-
          Many Linux distros are also moving that way :(
          (looking at you Ubuntu)
        2. I don’t see it that way (the M$ effect) . I see it as power available for the $. You have a ‘very cheap’ $5.00 to $8.00 part in hand. It does exactly what you want it to do in Python — not pushing any performance issues in doing so. Plus, modules in Python have already been created for just about every sensor or device you can think of with either CircuitPython or microPython . No need to re-invent the wheel here and drop to ‘C’ or Assembly and hack the registers. As long as does the job and is ‘reliable’, I really don’t see why Python is looked down on to use. In a recent project I even plugged a RP2350 into a small robotics board, so I could use it’s servo interface over i2c. Gave me control of 8 servos and two motors (not used in my project) without having to use Pico pins to do pwm and get power and ground to servos. Use the tech that is available I say. Time is to short to battle the low level hardware … if you don’t have to. Anyway, the Pico was again loafing along using Python with plenty of flash and memory to spare. And for the cheap cheap price … why not??? :)
        3. I partially agree.
          Software is getting more and more bloated which pushes users to more and more powerful hardware. An endless cycle.
          However older hardware also lacked important features. This caused software to become more complicated to work around these limitations or emulate the required features. Limited pointer size required segmented code, bank switching, long jumps, etc.
          We need more elegant software.
        4. I’ve seen several YouTube videos taking Contra Force and other older games and showing how, with a few simple patches, they could be optimized immensely. (See Displaced Gamers channel.) Amazing things could be done on older systems, but that doesn’t mean they were always or even usually done. In some ways, the limitations of older systems made quantity over quality worse; it’s a lot easier to pop out a 32-level platformer that gamers will play after SMB1, but a lot harder to make a passable quality Skyrim knock-off.
          We could talk about the UNIX effect, where original UNIX had a lot of fixed-sized buffers, usually with no check on buffer overflow. Code running in Python or Java can use flexible containers and flexible strings, with garbage collection to mitigate memory leaks. If it’s bloated and runs poorly, but unlike the efficient alternative, it runs without crashes, I think that’s a quality win.
          At the end of the day, if I’m writing code that will go in a microcontroller for a million products, there’s a good chance I want to go with a compiled language and optimize for the cheapest microcontroller available. If there’s going to be one made, spending a dozen hours of programmer time for to replace a Raspberry Pi 4 with something cheaper is wasteful. On a different scale, it’s important for a movie player to optimize so that 4K video can be played on cheaper systems. If the developers of LyX (a LaTeX editor) spent a hundred hours making it use half the memory and half the CPU, nobody would care; it runs just fine. Use that hundred hours on usability or features.
      2. You haven’t really contested the idea that “CircuitPython and MicroPython are fine for simple projects where performance is not a concern and provides an easy path into microcontrollers”
        The examples of tasks you’ve given are trivial, they do not use a fraction of a percent of the capability of a modern MCU, and are tasks that would otherwise be accomplished via simple analog components or ICs.
        Keep in mind a 20 year old ATmega2560 with 256kb of program memory and 8kb of RAM can run an 8 cylinder gasoline engine with sequential fuel and spark. The fact that you can write a basic IO program using a Python toolchain is inconsequential, you’re hardly utilizing the MCU to any real extent.
        1. I see people give simple examples like that for micropython all the time, I doubt they know what microcontrollers are actually capable of. Some of the examples they give (if a microcontroller had to be used) could likely be handled by a processor working in the low kHz range (if that), yet they think it impressive they can run it on a 32 bit, 100+MHz processor.
          Yes MCUs are cheap enough now that it makes sense to use python for some simple projects and even more so when it comes to SBCs running an OS but if you are doing anything that intensive or making something as a product then micropython just isn’t a good option. It is much slower and much less space efficient. The industries that use python the most, like AI or data analysis, they use python to call C functions, that is the only reason it is feasible to use.
          I tried a leetcode exercise in python, just a simple one, It was something simple like returning the maximum and minimum from a list. I first approached it logically in python, going through the list and comparing it against the current maximum and minimum, it was very slow and many many times slower than their best time, then I learned about the “pythonic” way to do it and it was a lot faster but made very little intuitive and obvious sense and required a lot of knowledge about python libraries and functions, like hash maps and built in sorting functions. Then I tried it in C and just did it logically and simply and it got close to the best time first attempt and was a fraction of the pythonic solutions time. My point being that python is good if you know all these functions and libraries which are written in a language like C. You can’t just approach it logically or mathematically and get good performance whereas with C and other languages a logical and mathematical approach often is best. I would say that in a lot of cases it can make python more difficult to write if you care about performance and more difficult to read.
          1. MicroPython modules can also be written in C, and often are for computationally intensive code. You can use the built-in ones, install general third party ones like ulab (for numpy) or emlearn-micropython for ML/DSP, or write your own.
            One can even install such native modules at runtime using “mip install”. Or bake them into the firmware. So what you suggest is plenty feasible already :) Non-trivial MicroPython projects are often a combination of C and Python. Or one could say all projects – as most of the low-level HAL modules shipped by default are implemented in C, along with the interpreter itself, of course.
    3. I agree completely. Python was for me a means to doing some work that required less mental investment than a compiled language. I assumed that C/C++ would take too long to grasp and be unwieldy. In the end I found that C was suitable for math/algorithmic work, but not a good choice for file input/output and raw data encoding from scratch (for png or wav for example). Python has perfect modules with easy and clean function calls. The math is far too slow in Python. I need to do computations that are time consuming. And C is the only feasible one unless Im willing to wait days/weeks to run in Python vs hours/days in C.
      1. You can combine C and Python with MicroPython, to get the best of both worlds. Write the computationally intensive parts in C and expose them as modules, then do the high level logic in Python.
  4. I develop FPGA modules and write embedded code for a living. At 100MHz the Zynq-7000 can toggle/read IO in ~150-200ns through the general purpose AXI interface between the PS-PL using canned peripherals from Xilinx, and 100-150 is using custom perioherals. It can be done in under 100ns if you stay in the PS only and use MIO GPIO. And the C code for that specific task is about the same number of lines as the python example.
    Don’t get me wrong, I use Python almost daily for testing and data analytics and it’s great for quickly whipping something up; but if performance really matters to you then just learn C for your embedded system.
  5. The missing information is, MicroPython can run 50 times faster than MicroPython with a couple built-in decorators and some style rules. From a demonstration by Damien George in 2018, I recently ran the examples on some new ESP32 boards and got the same results as the 2018 tests on STM32F407.
    It simply involves using local variables and functions and/or the @micropython.native decorator.
    2018 demonstration here. https://www.youtube.com/watch?v=hHec4qL00x0
  6. it’s a fun exercise but what i’d call “a solution in search of a problem.” the two questions i’d ask myself before starting this project would be:
    1/ python is a pretty fast interpreted language that has its place, but is there a really good reason to make python fast instead of just picking some other lanuage/execution model that’s inherently better suited to high performance applications?
    2/ what aspects of the python language/execution model might be factored out and implemented in hardware so that multiple interpreted languages benefit, e.g. math coprocessor, object oriented mmu, general purpose byte code interpreter that can be targeted by multiple languages, and so forth?
  7. I’ve been using a similar compiler tool chain concept for Thinkulator Dynamic, but instead I am targeting the native instruction set from off the shelf microcontrollers. It has benefits and drawbacks for sure. With a good UX, you can abstract the compile/load step away, letting you change things just as rapidly as a spreadsheet.
    This does make it MUCH less frustrating to change code on the fly. But it does not seem like they took this step yet.
    Them introducing their own CPU instruction set sounds similar to the old “It runs Java” gimmick, with the same challenges. It will be interesting that see how they take it, but it does remove some of the runtime reconfigurability with how they have implemented it so far.
    1. There’s very little of that in the discussions today, more of an attempt to quantify it on one hand, and how to get the most out of things like this on the other. No need for the pessimism.
  8. i’m with the guys who say, if you cared about performance, you wouldn’t be using python…and the ones who say, if you restrict yourself away from the idioms everyone actually uses in python, getting it to be fast isn’t too much of an accomplishment.
    but i’m simply bewildered by this project. it seems like compiling python is a real accomplishment. and investigating which kinds of ISA features would be handy for you if you were writing a python compiler is also interesting. for example, there’s papers out there about hardware reference counting.
    but this project, instead of making headway on the isolated components of the challenge, claims to do everything in one project. that would make this either one incredibly impressive project, or a bit of sleight of hand. given that the performance boast at the center of it is itself apples-to-oranges (!!!), i think the whole point is to write on a webpage the dubious sentence “PyXL runs Python directly in hardware — no VM, no OS, no JIT.” and they didn’t actually solve these interesting separate problems but in fact made a pidgin compiler that only supports enough for their contrived test case.
    i’m a negative nellie who perks up at compiler and ISA research and this smells like it ain’t that.
    1. Agreed. This is kinda fun (in the same way chips that run Java Bytecode were fun). It’s valuable in that it showed how the cheaper toolchain side could be done, and useful for connecting to people who might want to collaborate on taking it further..
      Still cool, but not yet useful. If they can take this further, and turn it into a product – they might put me out of business before I get my own solution on the market :LOL:
Leave a Reply to oldradiofixerCancel reply
