Keebin’ With Kristina: The One With The H.R. Giger Keyboard
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
I had to bust out Brain Salad Surgery to write this one, folks. It was that, or put on some Ministry or something. Just look at all the industrial-ness dripping from [heinn_dev]’s creation.
An incredibly industrial-looking split keyboard. Like, almost H.R. Geiger-esque.
Image by [heinn_dev] via reddit
Apparently [heinn_dev] wasn’t completely satisfied with his Chocofi case, and instead of requesting a full refund, just went ahead and made a prettier one. It took a lot of printing and even more sanding, but here we are. And it looks fantastic.
The only downside, if you can call it one, is that adjusting the tenting is a slow operatiJKon. But then again that’s one of those things that you usually set and forget.
Oh, and those keycaps are printed, too. As one commenter said, those homing nipples look painful, but I think it’s part of the charm. I just hope that hand grime doesn’t end up clogging the holes under the palm area. Clean your keyboards, people.
Serenity Now!
The Serenity keyboard, a split with dual trackballs and maybe one too many columns, IDK. I'd have to use it.
Image by [MKBR] via reddit
Maybe it’s the marshmallow keycaps, or the dreamy-white exposed dual trackballs, but I really dig the Serenity from [MKBR]. Is it endgame? Time will tell.
This is a 4-, 5-, or 6-column Corne layout, which is achieved with breakaway tabs on the PCBs. It uses an integrated RP2040 programmed with QMK/Vial and has hot-swappable MX switches.
Curious about the trackballs? I was, too — the left one is for scrolling, while the right is for regular trackballing around the screen.
The fact that it took around 85 tries to get AI to generate a good image for the back sounds about right, and looks to me like it was worth it. Go check it out in the gallery.
[MKBR] is a custom builder who has recently made a number of dystopian-themed boards, and although they’re all quite nice, Serenity is a refreshing alternative.
The Centerfold: LEGO My Tenting Setup
A split keyboard with LEGO built up to provide tenting.
Image by [koehr] via reddit
Tenting is such a personal thing, and getting just the right angle can take some doing. So why not give it a go with LEGO? That’s what [koehr] did, inspired by [spiritual-toe-2025] who did something similar about a week and a half ago.
So anyway, this is [koehr]’s Sofle RGB Choc, which has — you guessed it — Kailh choc switches. One of [koehr]’s priorities is to have the halves locked in place, which is easily achievable with bricks. Check out the third picture in the gallery and you’ll see a gap which allows the keyboard’s outer edges to rest on that cool desk mat.
Do you rock a sweet set of peripherals on a screamin’ desk pad? Send me a picture along with your handle and all the gory details, and you could be featured here!
Historical Clackers: Elliot-Fisher Book Typewriter
When we think of typewriters, no matter the type, we usually envision a single sheet of substrate moving through it, and usually against a platen.
A set of rails allows the paper to be fixed and the type elements to move.
Image via Museums Victoria Collections
Well, what if you needed to type in a ledger or other sort of already-bound book? Then you’d need a different beast entirely. You’d need the Elliot-Fisher Book Typewriter.
This machine debuted in 1903, although the design originated with the Elliot-Hatch Company around 1897. Unlike a traditional typewriter where the paper moves past a fixed point, the paper here is fixed, and the point of printing moves.
How is this done? With a set of rails. The typing mechanism moved along these rails to be positioned over the paper, effectively plotting the type. The typebars themselves were arranged vertically in a typebasket under the keyboard, and they rotated downward in order to strike the ribbon and paper.
As one typed, the entire keyboard and typebasket advanced along the rails. To do the next line, the machine move along another set of Y rails at right angles to the X rails. It’s unclear to me whether the book was fed through somehow, or one simply hefted the machine on top of it.
Finally, Cherry Unveils New Switches, Technology
Four new switches from Cherry!
Image by Cherry via Tom’s Hardware
At Computex 2025, Cherry announced “a bold new chapter” and debuted a total of four new switches: the IK, MX Honey, MX Blossom, and MX Falcon.
First and foremost is the new IK inductive switch, which uses their patented inductive sensing technology. Basically, it uses electromagnetic field detection and allows for contactless actuation, which means no mechanical wear, “even after millions of keystrokes”.
These IK switches are touted to consume 50% less power than standard magnetic switches and only 5% of the power that Hall-effect switches use. If that’s not enough for you, these IK switches have RGB and customizable actuation. They come out in Fall 2025.
Can’t wait for the IK switches? The MX Honey comes out in June and is Cherry’s first silent tactile MX switch, which sounds interesting (or doesn’t, I suppose). They allegedly have a newfangled spring and are pre-lubed at the factory.
Also coming in June is the Cherry MX Blossom, which will be their lightest linear switch ever with an actuation force of 35 cN. Finally, my favorite — the Cherry MX Falcon — will come out next month as well. This one is a tactile switch inspired by the community, and is reportedly for heavy typists and enthusiasts. It’s got a long-pole stem and has a sharper bottom-out and a richer sound. All three MX switches should be available as 36-switch kits soon. I can’t wait to get some!
Got a hot tip that has like, anything to do with keyboards? Help me out by sending in a link or two. Don’t want all the Hackaday scribes to see it? Feel free to email me directly.
19 thoughts on “Keebin’ With Kristina: The One With The H.R. Giger Keyboard
  1. Can someone tell me why many of these split and/or “wavy” keyboards don’t have arrow keys? (Apart ftom many of those photoed not having any key cap legends at all, it is clear there is usually not enough keys for 4 arrows).
    I can’t edit text, whether writing or programming, without arrows, or is that just me?
    1. Not a minimalist KB enthusiast, but I gather that things like that are put on “layers” that are swapped in and out using special keystroke macros. So, some other set of keys become arrows, then go back to being, idk, WASD or something.
      1. a. this is not true
        b. don’t be such a huge dick dude
        c. I’m not going to report your post which is pointless anyway, let you be you! Chinga con Dios!
      2. And you probably don’t even know why arrows are not used in vim (hint: because they were not used in vi either) (second hint: that reason is totally moot now)
    2. Arrows are for archers.
      But seriously: Usually one of the keys near your thumb is a “function layer” key (the others are space, “options” or any other macro).
      Pretty easy to memorize them. Especially if you ever learned stenography.
    3. These 40% and 60% keyboards rely on layers for the extra keys. This is an advantage as you do not need to move your fingers far from the home keys, reducing reach, and improving typing speed.
      Any designated key held can move you to a symbol or cursor layer. you don’t jsut need your thumb to do it
      And no-one needs letters/legends on a keyboard. The keys are always in the same place :-p
  2. “it uses electromagnetic field detection and allows for contactless actuation”
    So… I don’t need to even touch it? I type in the air above it?
    Or am I missing something?
    1. I believe the contact that is omitted is of the electrical variety.
      You still actuate the switch by moving something your finger and yet somehow the switch, or a circuit attached to the switch, knows that you have done so without the use of either an electrical contact or a magnet. I would guess it’s electronically sensitive to the compression of the metal spring.
Leave a Reply to I Alone Possess The TruthCancel reply
